Re: [N8VEM: 14632] Network - Using terminal server
Dylan -
Sorry for delay, family issues over past two weeks.
I also picked up surplus Avocent TS-100 w/o 5 VDC supply but have not had time on the bench with it.
Do you have a copy of the Install User Guide??
http://www.avocent.sk/Resources/Documents/Installer_-_User_Guides/Cyclades_TS100_Terminal_Server_Installer_User_Guide.aspx
IF this is a previously used TS-100 ... It likely has an earlier configuration (may be accessible via Ethernet port)
You can either modify that one OR reset to factory defaults.
Remember you are dealing with a full returned PowerPC processor with 32 Mb of memory and running Linux.
You need 2 RS-232 cables (you may need to build, if not in your kit), DE-9 female to DE-9 female.
One is all 9 pins wired straight through, the other is Avocents version of a Cross-Over (or null) cable.
Greg
