David,
As I recall, the video chip has what we called a "regen" buffer, which is a contiguous array of words, with the upper byte being the attributes and the lower word being the offset into the character generator table (usually ASCII). In the IBM-PC this was usually at segment 0xB800 and went on for 4000 bytes, that being 80*25*2.
So while the programmer may be thinking in row/column numbers, when it comes time to update the screen, the offset into the regen buffer is
Note: row and col are zero relative
NUMCOLS = 80
regenoffset = (row*NUM COLS*2)+(col*2)
or even more efficiently
regenoffset = ((row*NUM_COLS)+col)*2
To the chip, it doesn't think about rows and columns other than when painting the screen, it presents so many dots per line, and so on.
When the video BIOS is "positioning the cursor", it is really just calculating the new regen offset and doing what it takes to display a cursor in the appropriate spot.
Regards,
Douglas
Hello Douglas,
The comments in the source are merely documenting as I figure out
how the hardware works. The only question I have about the
software is that now it is using a 6545 rather than a 6845, is
there a speed/code size advantage by using row/column addressing
rather than straight binary? Considering the board has no
graphics capability and plenty of video RAM, it may speed things
up even more. Just a thought.
Regards
David
On 28/09/12 09:19, Douglas Goodall
wrote:
David,
The VDU code you are working with was actually based on code
that I wrote while
at DRI for the Olympia "PEOPLE" machine, which was a non-PC
compatible built
by the Olympia typewriter company in Wilhelmshaven (not sure
of the spelling) in
Germany. The XIOS was implemented to support both VT52 codes
for wordstar and
also a private set of escape sequences that were Olympia
specific. Also supported
were a set of escape sequences that allowed the programming
of soft function keys.
There was also a separate program called "function.a86" that
had a gui and used the
special escapes to alter the function table in memory. Being
a European company,
the 6845 initialization bytes were appropriate for the
Olympia supplied monitor and
other from the region.
If you have a question about the code, let me know.
Douglas
Hello Oscar,
I've recently got my VDU card running and have been adding
comments to the source code as I discover new things about
it. I can tell you that the firmware is set up for a PAL
monitor - it works at 312 lines non-interlaced at 50 fields
per second. Also the jumpers for the character clock must
be set as K1 2-3 (pin 3 of the 74669 HI) and K2 1-2 (pin 4
of 74669 LO). This gives an output of 2 MHz for the CLK
signal (pin 21 of the 6545-1). I'm using a 30 year old
green screen monitor on my board and after some adjustment
of the picture controls it has given a stable picture.
Hope this helps for a start.
Regards
David
On Thursday, 27 September 2012 18:28:41 UTC+9:30, oscarv
wrote:
Hi all, I recently completed a whole set of N8VEM boards (VDU,
Zilog Peripherals, Disk IO and the 6809 board) to expand
my N8VEM. I have one question on the VDU... this is quite an old
board by now so I wonder if anyone still has answers! The board works well with RomWBW 2.1 but the top line
of the screen is always garbled. See the picture: the
top line should just show 'dir'. Also, there is faint
but unusual 'ghosting' below the 25th line (second
picture).
I've read in the old postings that the 6545 CRT chip
sometimes needs tweaking of screen parameters, but I
doubt that is the problem here - I get the exact same
picture on two monitors. Both are PAL monitors but both
are supposed to be able to deal with NTSC (I don't think
that is where I should look for a solution). One monitor
actually developed a scary crackling noise after 10
minutes - but that may be unrelated, as it hasn't been
used for more than an hour in this century. I'm not sure where to start my bug hunt - any
suggestions are very welcome! Regards, Oscar.
You received this message because you are subscribed to the
Google Groups "N8VEM" group.
To view this discussion on the web visit https://groups.google.com/d/msg/n8vem/-/JvHzszIZs5IJ.
You received this message because you are subscribed to the Google
