Simple80 Rev 1
This is rev 1 of Simple80 with the compact flash interface integrated on board. The motherboard has all necessary hardware to run CP/M. It is no longer zero glue logic like the Simple80, but is software compatible with the original Simple80.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_simple80_dsc_54701221.jpg
  • Z80 at 7.3728MHz
  • Dual serial port SIO
  • 128K RAM
  • 64K PROM or EEPROM
  • Three classic RC2014 expansion connectors
  • 100mm X 100mm pc board
  • Compact flash interface
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_simple80_dsc_54711221.jpg
Theory of operation
Simple80 Monitor rev0.6, a basic monitor for Simple80. Use this monitor to initialize CF disk and load CP/M2.2 BIOS/CCP/BDOS.
XMODEM.hex, this is the xmodem file transfer program in Intel Hex format.
CPM22_unarj, this zipped file contains two files: cpm22dri.arj is compressed CP/M2.2 distribution files; and unarj.com is file needed to decompress dpm22dri.arj. These two files need to be loaded into CF disk use xmodem.
Manuals
Getting started with Simple80. This is the instruction for installing software in Simple80.
builderpages/plasmo/simple80r1.1601347688.txt.gz · Last modified: 2020/09/28 22:48 by plasmo
