Simple80 Rev 1
This is rev 1 of Simple80 with the compact flash interface integrated on board. The motherboard has all necessary hardware to run CP/M. It is no longer zero glue logic like the Simple80, but is software compatible with the original Simple80.
- Z80 at 7.3728MHz
- Dual serial port SIO
- 128K RAM
- 64K PROM or EEPROM
- 100mm X 100mm pc board
- Compact flash interface
Theory of operation
Simple80 Monitor rev0.6, a basic monitor for Simple80. Use this monitor to initialize CF disk and load CP/M2.2 BIOS/CCP/BDOS.
XMODEM.hex, this is the xmodem file transfer program in Intel Hex format.
CPM22.arj, this is compressed CP/M2.2 distribution files. Use unarj.com below to decompress.
Manuals
Getting started with Simple80. This is the instruction for installing software in Simple80.
