Simple80 Rev 1
This is rev 1 of Simple80 with the compact flash interface integrated on board. The motherboard has all necessary hardware to run CP/M. It is no longer zero glue logic like the Simple80, but is software compatible with the original Simple80.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_simple80_dsc_54701221.jpg
  • Z80 at 7.3728MHz
  • Dual serial port SIO
  • 128K RAM
  • 64K PROM or EEPROM
  • Three classic RC2014 expansion connectors
  • 100mm X 100mm pc board
  • Compact flash interface
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_simple80_dsc_54711221.jpg
Theory of operation
Simple80 Monitor, a basic monitor for Simple80. Use this monitor to initialize CF disk and load CP/M2.2 BIOS/CCP/BDOS.
builderpages/plasmo/simple80r1.1576942110.txt.gz · Last modified: 2019/12/21 10:28 by plasmo
