Tiny68K, 68000 SBC, Rev 2
- The Compact Flash interface of rev 1 is marginal. It may not work with faster CF drives due to ground noises generated by faster CF drives. Rev 2 design added isolation resistors to the data line, RC circuitry to the nIORD control line, and pull up resistors to the upper half of the 16-bit data line
- A 'warm boot' button is added that will generate a non-maskable interrupt to the 68000 when pressed.
- Add a real-time clock based on DS1302 that is backed up with a super capacitor.
Rev 2 Design Files
gerber photo plots, pc boards were manufactured by SeeedStudio
Part list
Altera EPM7128 files
Monitor
