SBC-V1
The SBC-V1 is the creation of Andrew Lynch. Formerly known as the N8VEM Z80 SBC after Andrews call sign, it launched a tsunami of developments based on the Euro Card Bus (ECB) standard. Much of the initial records on development from 2006 have been lost but some pictures remain and the evolution can be picked up from the April-2008 archive
https://www.retrobrewcomputers.org/lib/plugins/ckgedit/fckeditor/userfiles/image/boards/sbc/sbc_v2/sbc_v1/gallery/n8vem-mk1z80-768x434.jpg?nolink&768x434
Picture courtesy vintagevibe.co.nz
Changes from V1
