SBC-V1
https://www.retrobrewcomputers.org/lib/plugins/ckgedit/fckeditor/userfiles/image/boards/sbc/sbc_v2/sbc_v1/gallery/n8vem-mk1z80-768x434.jpg?nolink&768x434
Picture courtesy vintagevibe.co.nz
Changes from V1
