Re: [N8VEM: 14549] N8-2312 up and running (video)
Hi Max,
I'm almost certain that the 2312 variant of the board corrected all of that.  Those issues were on the 2511.  Also, the 2312 supports CSIO with no board mods.
Thanks!
Wayne
On Saturday, September 1, 2012 12:25:07 AM UTC-7, Max Scane wrote:
Hi Douglas,
From memory, there is a trace cut you need to make on that board.  As it is the trace pulls one of the SD card lines up to 5V.  Also, I'm not sure which driver you are using but, the board is setup to use spare bits in the RTC IO address rather than the CSIO port of the Z180 for the SD card.  Probably a couple of additional trace cuts required there as well.
Regards,
Max
Sent from my iPad
On 01/09/2012, at 6:47 AM, Douglas Goodall <dougl...@mac.com> wrote:
> Friends,
> The video output of the TMS9918 is functioning today. The only obstacle now
> between me and great graphics is learning the chip. I put a PDF of the chip's
> programming manual in my journal on the wiki.
> I am using a vintage Apple ][ monochrome display and it looks properly vintage.
> I am continuing to be delighted by the efforts made on the design of the 2312
> motherboard, as many things are working right out of the gate. I am still having
> trouble with the SD support. Now I am using SanDisk chips and still having
> trouble so next thing is to obtain an SD extender widget so I can verify the signal
> integrity between the 3M socket and the board.
> The PPIDE is rock solid and the editing and build processes
> I bought two variable resistors for RV1 and RV2, but they were slightly too large to
> sit in their pads next to each other. Make sure to buy small footprint components for
> these.
> I have two 512KB memory chips installed, so I changed the RAMSIZE configuration
> variable to 1024 instead of the default 512.
> I am having big fun now :-)
> Douglas
> For more options, visit this group at http://groups.google.com/group/n8vem?hl=en.
