Hi friends,
I´m starting during my holiday with building the N8-2312 version.
Are there all actual documents (schematic, PCB, BOM) on the WikI?
Regards
Wolfgang
Am 01.09.2012 17:40, schrieb Wayne Warthen:
Hi Max,
I'm almost certain that the 2312 variant of the board
corrected all of that. Those issues were on the 2511. Also,
the 2312 supports CSIO with no board mods.
Thanks!
Wayne
On Saturday, September 1, 2012 12:25:07 AM UTC-7, Max Scane
wrote:
Douglas,
From memory, there is a trace cut you need to make on that
board. As it is the trace pulls one of the SD card lines up
to 5V. Also, I'm not sure which driver you are using but, the
board is setup to use spare bits in the RTC IO address rather
than the CSIO port of the Z180 for the SD card. Probably a
couple of additional trace cuts required there as well.
Regards,
Max
Sent from my iPad
On 01/09/2012, at 6:47 AM, Douglas Goodall <dougl...@mac.com>
wrote:
> Friends,
> The video output of the TMS9918 is functioning today. The
only obstacle now
> between me and great graphics is learning the chip. I put
a PDF of the chip's
> programming manual in my journal on the wiki.
> I am using a vintage Apple ][ monochrome display and it
looks properly vintage.
> I am continuing to be delighted by the efforts made on
the design of the 2312
> motherboard, as many things are working right out of the
gate. I am still having
> trouble with the SD support. Now I am using SanDisk chips
and still having
> trouble so next thing is to obtain an SD extender widget
so I can verify the signal
> integrity between the 3M socket and the board.
> The PPIDE is rock solid and the editing and build
processes
> I bought two variable resistors for RV1 and RV2, but they
were slightly too large to
> sit in their pads next to each other. Make sure to buy
small footprint components for
> these.
> I have two 512KB memory chips installed, so I changed the
RAMSIZE configuration
> variable to 1024 instead of the default 512.
> I am having big fun now :-)
> Douglas
> You received this message because you are subscribed to
the Google Groups "N8VEM" group.
> For more options, visit this group at http://groups.google.com/group/n8vem?hl=en.
You received this message because you are subscribed to the Google
To view this discussion on the web visit https://groups.google.com/d/msg/n8vem/-/rV3a8WA0ckcJ.
Dr.-Ing. Wolfgang Kabatzke
Hansastrasse 9
DE - 21 502 Geesthacht
Deutschland / Germany
Phone: +49 4152 93 18 130 NEW!!!
