Currently supporting CP/M 2.2 and CP/M 3.0 | This ia a fork of Takashi TOYOSHIMA's CP/Mega88 project (https://github.com/toyoshim/cp-mega88 ), only focussing on the AVR implementation. The project features an Intel 8080 emulator, running in an ATmega88 AVR, in a virtual machine which runs CP/M 2.2 and 3.0. (dual boot) This is a work in progress. Although the system is functional, it is not yet finished. Inside you will find all the files you need to build the system CP-Mega88 | |
Currently supporting: CP/M 2.2, Dos+ 2.5, ZSDOS 1.1/ZCPR 2, CP/M 3, ZPM3 and NASCOM “ROM” BASIC 4.7 | In march 2007 Grant Searle introduced “CP/M on Breadboard”, a 9 chip Z80 CP/M computer using a CF card as mass storage device. (http://searle.hostei.com/grant/ ) I got inspired by his work and created my own version SBC-2G-512k | |
Currently supporting: CP/M 2.2, Dos+ 2.5, ZSDOS 1.1 / ZCPR 2, MP/M, CP/M 3, ZPM3 and NASCOM “ROM” BASIC 4.7 | An FPGA implementation of the earlier mentioned Z80 system. Because the configuration supports a 50 Hz interrupt signal, MP/MII was added to the set of supported operating systems. The system is laid out to run on Altera Cyclone II (EP2C5) miniboard The board shown is a compact version of a CycloneII-c board with added serial interface connectors (4 in total) and 5v keyboard interface MC-2G-1024k | |
In answer to popular demand: yes there is a Cyclone IV version too These are the VHDLs, Cyclone IV.zip I use the version 130 Quartus software My miniboard is fitted with a 50 MHz oscillator The board shown is compact version of James Moxham's work with 4 serial interface connectors and a 5v keyboard interface. Schematics and Gerbers are here: | ||
On Serial - USB interfaces Following the FTDI 232 soap I found the following units based on the CP2102 chip to be cheaper and better. It is a 3v3 unit with voltage converter built in, but the inputs are 5v tolerant. A 5v Z80 SIO has no trouble with the 3v3 outputs. All necessary modem lines are available. There is also a 500 mA polyfuse in the 5V line The board turns into a neat USB plug using a length of heat shrink tube. look on eBay. They cost about $1.25 each |
