ZZRCC Bootstrap ROM
This is the listing of the small bootstrap ROM inside of EPM7032S CPLD
;12/5/20 ;32-byte ROM inside CPLD ;check for CF disk not busy, then read the master boot record to 0xB000 ; execute the program starting from 0xB000 CFdata equ 010h ;CF data register CFerr equ 011h ;CF error reg CFsectcnt equ 012h ;CF sector count reg CF07 equ 013h ;CF LA0-7 CF815 equ 014h ;CF LA8-15 CF1623 equ 015h ;CF LA16-23 CF2427 equ 016h ;CF LA24-27 CFstat equ 017h ;CF status/command reg org 0 nop nop nop ld hl,0b000h ;bootstrap code starts from 0xb000 ; check for disk not busy readbsy: in a,(CFstat) ; read CF status and 80h ; mask off all except busy bit jr nz,readbsy ;reg A is already 0 ld b,a ;make reg B zero ;; do not need to set up sector/track and sector count because ;; they are set by default after reset ; out (CF1623),a ; track 0 ; out (CF815),a ; inc a ;master boot sector is sector 1 ; out (CF07),a ;read master boot sector (sector 1) ; ld c,CFdata ; reg C points to CF data reg ; out (CFsectcnt),a ; write to sector count with 1 ld a,20h ; read sector command out (CFstat),a ; issue the read sector command chkdrq: in a,(CFstat) ; check data request bit set before write CF data and 8 ; bit 3 is DRQ, wait for it to set jr z,chkdrq inir ;z80 read 256 bytes jp 0b000h ;execute loaded program end
