Simple80 Rev 1
This is rev 1 of Simple80 with the compact flash interface integrated on board. The motherboard has all necessary hardware to run CP/M. It is no longer zero glue logic, but is software compatible with the original Simple80.
- Z80 at 7.3728MHz
- Dual serial port SIO
- 128K RAM
- 64K PROM or EEPROM
- 100mm X 100mm pc board
- Compact flash interface
Theory of operation
Schematic of SimpleCF, a simple compact flash interface for Simple80
PC board Gerber files of SimpleCF, a simple compact flash interface for Simple80
Bill of Materials for SimpleCF
Simple80 Monitor, a basic monitor for Simple80. Use this monitor to initialize CF disk and load CP/M2.2 BIOS/CCP/BDOS.
