Simple80 Rev 1
This design was inspired by low-cost Z80 kit listed on eBay. The motivation is to build a CP/M-ready, RC2014-compatible Z80 SBC with part cost of about $20.
- Z80 at 7.3728MHz
- Dual serial port SIO
- 128K RAM
- 64K PROM or EEPROM
- 100mm X 100mm pc board
- No glue logic design
Theory of operation
Schematic of SimpleCF, a simple compact flash interface for Simple80
PC board Gerber files of SimpleCF, a simple compact flash interface for Simple80
Bill of Materials for SimpleCF
Simple80 Monitor, a basic monitor for Simple80. Use this monitor to initialize CF disk and load CP/M2.2 BIOS/CCP/BDOS.
