Simple80, a simple Z80 SBC with no glue logic
This design was inspired by low-cost Z80 kit listed on eBay. The motivation is to build a CP/M-ready, RC2014-compatible Z80 SBC with part cost of about $20.
Z80 at 7.3728MHz
Dual serial port SIO
128K RAM
64K PROM or EEPROM
Three classic RC2014 expansion connectors
100mm X 100mm pc board
No glue logic design
Theory of operation
Schematic of SimpleCF, a simple compact flash interface for Simple80
PC board Gerber files of SimpleCF, a simple compact flash interface for Simple80
Bill of Materials for SimpleCF
Simple80 Monitor, a basic monitor for Simple80. Use this monitor to initialize CF disk and load CP/M2.2 BIOS/CCP/BDOS.
builderpages/plasmo/simple80r1.1563883193.txt.gz · Last modified: 2019/07/23 07:59 by plasmo
