Improved 512K RAM ROM Board, Rev1
Rev1 version simplifies the original design and uses all through-hole components for ease of assembly. It also added a oscillator so a functioning system can be built with a Z80 CPU board and a version 1 512K RAM/ROM board.
- Support ROMWBW
- ROM emulation, with few jumper configurations, the ROM socket can be populated with RAM and data uploaded into the RAM via serial port at 115200 baud,
- EPROM programmer, programming software can be loaded in RAM to program the EPROM,
- A serial port, the same serial port used to load ROM image can be reuse as a regular serial port.
- Spare capacities and I/O pins on CPLD for other user-defined functionalites.
- Faster, nominal speed is 14.7456MHz but can be overclocked to 22MHz
- Economical, the board should be around $50.
Applications
EPROM Programmer
The jumper configuration of RR512K_rev1 is
- T24 jumper to ground
- T22 jumper to ground
- T25 jumper to T27
- T26 jumper to T28
RR512K Loader v0.1 4/21/20
Auto start at 0xB400
Programmer for SST39SF040 ver 0.2 4/23/20
SST39SF040 will now be erased
Enter 'Y' (upper case Y) to chip erase SST39SF040 EPROM or any other character to cancel the operation. Once chip is erased, the program will prompt user to send the image file in Intel Hex format:
………………………………………….. (truncated) ………………………….X
