Rev0 KIORC Engineering Change for 32x16KB banks
This engineering change is needed to convert rev0 KIORC pc board to emulate memory bank scheme of RC2014 512K RAM/ROM board
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_kiorc_dsc_71131130.jpg
  • 5K pullup resistor for channel B receive; VCC to one terminal of 5K resistor, pin 3 of channel B serial connector to other terminal.
  • RTS handshake to channel A; RTSA (KIO pin 29) to pin 1 of channel A serial connector.
  • RTS handshake to channel B; RTSB (KIO pin 14) to pin 1 of channel B serial connector
  • KIO clock out connect to Channel A & B transmit and receive clocks and Clock 1 and 2 trigger inputs; KIO clock out is already connected to Channel A & B transmit and receive clock. Clock 1 and 2 trigger inputs are pin 73 and 74 of KIO which is connected to pin 4 (TXCB) of KIO.
  • KIO's ASTA and ASTB need to be pulled up; connect KIO pin 61 (VCC) to one terminal of 4.7K resistor, connect the other terminal of the resistor to pin 44 and 46 of KIO
  • Ground KIO's DCDA and DCDB, pull down KIO's CTSA and CTSB; connect KIO pin 10 (GND) to KIO pin 8(DCDA), pin 7(DCDB); solder 0603 1K resistors between pin 6 and pin 8 of KIO and again between pin 7 and pin 9 of KIO thus pulling CTSA and CTSB to ground through 1K resistors.
builderpages/plasmo/kiorc/rev0ec.txt · Last modified: 2022/11/30 20:51 by plasmo
