Pictorial Assembly Guide of K80
The order of assembly is based on the height of the components, the lowest components are soldered down first and the tallest last.
Bare PC board, component side
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_k80_pic_assembly_guide_k80_bare_pcb_comp.jpg
Bare board, solder side
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_k80_pic_assembly_guide_k80_bare_pcb_solder.jpg
Install the resistors first; the resistors are all 4.7K except R3 (indicated by a red arrow) which is 2.7K.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_k80_pic_assembly_guide_k80_resistor_comp.jpg
Install capacitors next; capacitor values are all 0.1uF except C12 and C13 (indicated by red arrows) which are 33pF.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_k80_pic_assembly_guide_k80_res_cap_comp.jpg
Install IC sockets.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_k80_pic_assembly_guide_k80_ic_sockets_res_cap_solder.jpg
Install PLCC sockets, observe the orientation of the sockets as indicated by the red arrows.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_k80_pic_assembly_guide_k80_plcc_ic_socket_res_cap.jpg
The completed board.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_k80_pic_assembly_guide_k80_all_assembled.jpg
11/15/23. Engineering changes for KIO
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_k80_pic_assembly_guide_dsc_74761115.jpg
builderpages/plasmo/k80/pic_assembly_guide.txt · Last modified: 2023/11/15 21:32 by plasmo
