Pictorial Assembly Guide for partially assembled CB030
CB030 is available as partially assembled pc board where all the surface mount components are soldered and the CPLD is programmed. This pictorial guide show how the remaining through-hole components are assembled step-by-step.
This is the partially assembled CB030, component side and solder side. This is the starting point of the pictorial assembly guide.
Click on a photo for high resolution picture.
Add IC sockets
Add discrete capacitors and resistors. Note location of pin 1 of the SIP resistor
Add connector and headers.
Finally, add the SIMM72 socket and Compact Flash adapter. Note the pin 1 of SIMM72 socket
Completed CB030 with components
