SBC V2-005 MEGAFLASH
  • 4Mhz+ Zilog Z80 CPU.
  • 512Kb paged SRAM.
  • 1Mb Flash ROM.
  • Serial Interface.
  • IDE interface.
  • Real Time Clock.
  • Onboard sound.
  • Standard ECB bus interface.
  • Reset button.
  • Recovery mode button.
  • Status LED.
  • Switchable clock speed.
Software Support
ROMWBW BIOS featuring:
  • CP/M / ZSDOS
  • RAM & ROM disk support.
  • Prebuild disk images
  • RAMFLOPPY - Up to 2 x 4Mb memory drives.
  • VDU - Composite VDU monitor and keyboard support.
  • CVDU - Colour VDU and keyboard support.
  • VGA3 - Colour VGA display board and keyboard support
  • Zilog Peripherals - 2xSerial ports, counter timer chip.
  • USB FIFO - USB serial interface
  • Disk I/O - 3.5“, 5-1.4”, 8“ floppy disk and parallel port IDE.
  • 4PIO - Parallel interface card.
  • SCG - Graphics and sound board.
  • DUAL SD CARD - SD Card based memory drive
  • MF-PIC - Colour VGA, keyboard interface.
Board
Gerbers for SBC V2-005c here.
Changes from SBC V2-004
  • Software support for programming dual chips.
  • Driver support for accessing ROM drive as a read and write filesystem.
C2110uFElectrolytic Capacitor
C3410.22F+Super Capacitor
D115mm LEDRed/Green Bicolor
D211N4148Diode
P212.1mmBarrel Jack Socket
Q112N3906PNP Transistor
R1110R0.25w resistor
R2,R11210K0.25w resistor
R91100R0.25w resistor
R1214K70.25w resistor
R1313K60.25w resistor
R1411K80.25w resistor
R151120R0.25w resistor
R161470R0.25w resistor
R171100K0.25w resistor
RR214K7SIP-6 Resistor array
U1116550UART DIP40 socket 1
X1132.768KHz3mm Crystal 6pF
Sockets 31154232
Minimum Build
ReferenceComponent
C210uF
D21N4148
JP3-JP4SOLDER BRIDGE
JP4-JP8SOLDER BRIDGE
P2BARREL JACK
P3IDC SOCKET
P44-10MHz XTAL + SOCKET
P51.8432 XTAL
U116550
U374LS08
U474LS10
U674LS139
U774LS14
U12, U13, U1874LS174
U14, U15, U1674LS32
U1774LS244
U23AS6C4008
U24Z80CPU
U2674LS06N
U2874LS74
U2939SF040
K10Pin Header, 1-2 BRIDGED
K11Pin Header, 1-2 BRIDGED
R110R
R210K
RR1, RR210K
RR34K7
SW1Push Button
SBC Build
Excludes ECB interface
ReferenceComponent
C6, C18, C33, C350.1uF
C24-C271uF
C2810uF
D1BICOLOUR LED
JP1PIN HEADER
JP2PIN HEADER
JP3-JP4REMOVE SOLDER BRIDGE
JP5-JP8REMOVE SOLDER BRIDGE
JP9PIN HEADER
K12PIN HEADER, 2-3 BRIDGED
LS1PIN HEADER
P1IDC SOCKET
Q12N3906
R9100R
R1110K
R124K7
R133K6
R141K8
R15120R
R16470R
R17100K
U239SF040
U574LS125
U198255
U21DS1302
U22MAX232
U24DS1210
U2774LS14
SW2Push Button (Revision f+)
Full Build
ReferenceComponent
C1, C5, C7, C10,0.1uF
C3122uF
U8, U9, U1174LS245
U1074LS243
U20DIN EURO MALE RA 96
Boot ROM Installation
To assemble a 1024Kb ROMWBW rom, use the following as an example command line in the Source directory: build SBC std 1024 . The finished ROM image will be saved in the \Binary subdirectory. Before programming, split the file into 512Kb parts using a tool such as HxD.
  • Serial port.
  • Real Time Clock
  • Colour VDU board.
  • VGA board.
  • Parallel Port IDE.
  • Propeller IO.
#DEFINE SBCV2004
Flash Programming
Will Sowerbutts has updated his FLASH4 program to support programming one or more flash chips. The updated Flash4 can be found in Will Sowerbutts github repository https://github.com/willsowerbutts/flash4 and is also included in the current development release of ROMWBW. As the RAM disk on the SBC V2 is smaller then 512Kb, the ROM image to be programmed must reside on an alternate storage device such an IDE flash card.
An example command line to update ROMWBW would be b:flash write std512.rom /1 or b:flash write cust1024.rom /2 for a 512Kb or 1024Kb ROM respectively.
Acknowledgement
Thank you Andrew!
Contact
boards/sbc/sbc_v2/sbc_v2-005.1607956596.txt.gz · Last modified: 2020/12/14 09:36 by b1ackmai1er
