SBC V2-005 MEGAFLASH
  • 4Mhz+ Zilog Z80 CPU.
  • 512Kb paged SRAM.
  • 1Mb Flash ROM.
  • Serial Interface.
  • IDE interface.
  • Real Time Clock.
  • Onboard sound.
  • Standard ECB bus interface.
  • Reset button.
  • Recovery mode button.
  • Status LED.
  • Switchable clock speed.
Board
Gerbers for SBC V2-005c here.
Changes from SBC V2-004
C2110uFElectrolytic Capacitor
C3410.22F+Super Capacitor
D115mm LEDRed/Green Bicolor
D211N4148Diode
P212.1mmBarrel Jack Socket
Q112N3906PNP Transistor
R1110R0.25w resistor
R2,R11210K0.25w resistor
R91100R0.25w resistor
R1214K70.25w resistor
R1313K60.25w resistor
R1411K80.25w resistor
R151120R0.25w resistor
R161470R0.25w resistor
R171100K0.25w resistor
RR214K7SIP-6 Resistor array
U1116550UART DIP40 socket 1
X1132.768KHz3mm Crystal 6pF
Sockets 31154232
Flash Programming
Will Sowerbutts has updated his FLASH4 program to support programming one or more flash devices.
To assemble a 1024Kb ROMWBW rom, use the following as an example command line: buildrom SBC std 1024
The updated Flash4 can be found in Will Sowerbutts github repository https://github.com/willsowerbutts/flash4
Minimum Build
ReferenceComponent
C210uF
D21N4148
JP3-JP4SOLDER BRIDGE
JP4-JP8SOLDER BRIDGE
P2BARREL JACK
P3IDC SOCKET
P44-10MHz XTAL + SOCKET
P51.8432 XTAL
U116550
U374LS08
U474LS10
U674LS139
U774LS14
U12, U13, U1874LS174
U14, U15, U1674LS32
U1774LS244
U23AS6C4008
U24Z80CPU
U2674LS06N
U2874LS74
U2939SF040
K10Pin Header, 1-2 BRIDGED
K11Pin Header, 1-2 BRIDGED
R110R
R210K
RR1, RR210K
RR34K7
SW1Push Button
SBC Build
Excludes ECB interface
ReferenceComponent
C6, C18, C33, C350.1uF
C24-C271uF
C2810uF
D1BICOLOUR LED
JP1PIN HEADER
JP2PIN HEADER
JP3-JP4REMOVE SOLDER BRIDGE
JP5-JP8REMOVE SOLDER BRIDGE
JP9PIN HEADER
K12PIN HEADER, 2-3 BRIDGED
LS1PIN HEADER
P1IDC SOCKET
Q12N3906
R9100R
R1110K
R124K7
R133K6
R141K8
R15120R
R16470R
R17100K
U239SF040
U574LS125
U198255
U21DS1302
U22MAX232
U24DS1210
U2774LS14
SW2Push Button (Revision f+)
Full Build
ReferenceComponent
C1, C5, C7, C10,0.1uF
C3122uF
U8, U9, U1174LS245
U1074LS243
U20DIN EURO MALE RA 96
Boot ROM Installation
To assemble a 1024Kb ROMWBW rom, use the following as an example command line in the Source directory: buildrom SBC std 1024 . The finished ROM image will be saved in the \Binary subdirectory. Before programming, split the file into 512Kb parts using a tool such as HxD.
  • Serial port.
  • Real Time Clock
  • Colour VDU board.
  • VGA board.
  • Parallel Port IDE.
  • Propeller IO.
If the JP2 jumper “1BIT-IN” is bridged the default console will switch from Serial port to the first vidoe card.
Some suggest configuration changes to take advantage of SBC V2-004+ features:
#DEFINE SBCV2004
Acknowledgement
Thank you Andrew!
Contact
boards/sbc/sbc_v2/sbc_v2-005.1607169374.txt.gz · Last modified: 2020/12/05 06:56 by b1ackmai1er
