Multicomp Papilio Duo (Xilinx Spartan-6)
Welcome to my recently completed Project using the awesome Papilio Duo platform with the Classic Computing Shield (Xilinx Spartan 6). It's a migration of Grant Searle's brillant work called MULTICOMP, consisting in a flexible FPGA based architecture for implementing old style 8 bit Retro-computers using Z80, 6502 & 6809 “Soft-core” CPU's. You can take a look at the original Project, based on an Altera Cyclone II dev board, following this link: (Link to Grant's web site)
4. In my first attempt I adapter the CPU and Baudrate clock generators, to use the Papilio's 32 MHzOSC instead of the original 50 MHz, but I ran into timing problems converting the many clock -dependant constants in the design. So I decided to generate a new 50 MHzclock using the DCM & PLL Wizard.
Hope you enjoy it !
Hardware & FPGA Bitstream Documentation
I've attached some pictures of my working system and the full VHDL ISE 14.7 Project tree files, including an already generated “bit” file for transferring it to the Papilio Duo with the Computing Shield attached (default serial port baudrate is 9600, 8N1 no handshake).
I've also included a ready to go SD card image (SD only, not SDHC for now, 1 or 2 GB) with all the CP/M partitioning work already done including a very comprehensive software collection courtesy of Oscar Vermeulen (drives A to D, Users 0 to 9).
Link to Project files:
https://app.box.com/s/g5wiv2aobx9d4ctypjnvyp9wpgtqj43f
Link to SD Card image with CP/M 2.2 Software Collection:
Builder's Notes/Comments
Please use this space to add any notes/comments on this board that don't fit into the above sections. (Periodically, these comments may be re-arranged to be better incorporated into a new revision of the wiki page.) Please sign your comments using the wiki “Insert Signature” feature! — — Andrew Bingham 2016/09/14 12:21
Photo Gallery
multicomp_cpm_demo_disk_image.zip | 194.6 MiB | 2016/09/19 22:50 |
multicompcpm-papilioduocs-jlc.zip | 24.5 MiB | 2016/09/15 17:57 |
