Multicomp Cyclone II-B
The Multicomp Cyclone II-B (v1.09) is a motherboard which provides peripheral connectivity for a Cyclone II FPGA development board commonly available on eBay. The board was designed by James Moxham and Max Scane and provides connectivity for the following peripherals:
- VGA Screen with PS/2 Keyboard interface
- Two RS-232 serial ports with DE-9F connectors
- SD Card connector
- Two RAM sockets to support up to 1 MB of RAM.
- Unused signal breakout and prototyping area
- DC Jack for 5 Volt power input
Due to the header installation on the Cyclone II module, the module is required to be mounted inverted onto the motherboard.
Z80 Emulation Features
The Z80 Emulation VHDL code is based on Grant Searle's original Multicomp which has been extended to support additional peripherals and features
The VHDL code includes the following enhanced features:
- Memory Management Unit supporting up to 1MB of physical RAM with 16KB pages
- Fixed Baud-rate for all serial ports
- 20 ms interrupt generator
These features are supported in the ROM-MJS Enhanced Monitor
Resources
Documentation
cyclone-ii-b-schematic.pdf | 54.2 KiB | 2016/01/03 23:13 |
Z80 Emulation Code
multicomp-_z80-cycloneiib-pof.zip | 85.8 KiB | 2016/01/04 00:45 |
