Gryphon68030
About
- The 68K/CPU32 instruction set is generally acknowledged as one of the better ISAs
- A lot of folks have a fondness for the 68K - the heart of Amigas, Ataris, Macs and others, and a time when we cut our teeth learning computers
- The '030 is the last of the Motorola line that is relatively easy to work with
- Clock speed of 25MHz is probably the limit of 2 sided PCB designs before entering RF voodoo land
Other design decisions:
- Why is the video on a daughterboard? The S1D13505 chip has 0.5mm spacing. Cost for the whole board goes up to accomodate the one chip. A decision was made to use an adapter board to help control costs.
- Why the S1D13505? The Epson chip has the most thorough documentation of anything I could find and it met the design goal of at least 800×600 color video
- Why a floppy disk interface? A true anachronism. I just thought it would be neat to understand how FDDs work. No other reason.
- Why are you doing this when you could (emulate, buy eval board, hack other 68k systems, etc)? You already know the answer or you wouldn't be on this page. It's a hobby and a learning experience.
- Why is there an image of you on the back of the board? Are you an egomaniac? This started out as a personal project. It was only after I had the gerbers ready to send to production that I decided to share the project. This is my contribution to the free hardware/software community for so much that I have benefited from over the years. Rev1.1 will not have my image.
Primary Designers:
- Paul D. Fincato - NM156
- David Mehaffy - Yoda
Specifications
- MC68030 @ 25MHz
- MC68882 @ 25MHz
- 32M DRAM via 8422V Controller
- 512K SRAM (to help get it initially running)
- 512K FLASH
- Parallel Port
- 2 Serial Ports
- 8242 Keyboard/Mouse Controller
- AY-3-8910 Sound
- 37C65 FDC
- IDE interface
- RTC 72421 Clock
- RTL8019AS Ethernet
- S1D13505 Video (800×600) - (In a TQFP-128 to PGA-128 SMT Adapter)
Current Version: Rev 1.00
PCB Design Files: gryphon68030-1.00-proteus.zip (Note: The Gryphon was designed using Proteus 8.0 by Labcenter Electronics. A project to convert the design into KiCAD has started in this RBC forum thread.)
Address Decode Table: gryphon68030-1.00-addressdecode.pdf
- Current list of erratas, documentation and updated GAL equations.
- Rev 1.1 schematic with all erratas incorporated to date. This will be used as the basis of the new KiCAD EDA based version of the project.
Rev 1.0 BOM
Progress & Updates
28 MAY 2015
- The DP8422 DRAM controller is now functional. Preliminary byte, word and long read/writes are successful. Minor changes to byte decode, DRAM glue GAL equations and a trace swap required.
- Exhaustive DRAM testing will begin soon for entire 32M address space
- There is still an issue with 8422 CS programming that fails to initialize properly after reset on occasion. Investigation into this is ongoing.
28 APRIL 2015
- With a few minor erratas applied the AY-3-8910 and VT82C42 check out
- Minimal code was written it ID the coprocessor installed. It identified the 68882 when installed and crashed F-line (as expected) when removed
- Schematics have been updated with latest errata changes and will be posted soon.
15 APRIL 2015
- A basic monitor was written to view memory, disassemble and download SRECs. Has been burned to FLASH and is now running on hardware.
- DRAM issue has not yet been resolved, but having a basic monitor will help debugging by eliminating the burn/replace FLASH cycle
- Yoda is currently working on unifying the code and working toward a standardized 68k monitor
27 MARCH 2015
- NM156 has successfully tested the serial port. Yoda reminded me that CTS must be asserted for the DUART to spit characters.
- Work is continuing on getting DRAM functional
22 MARCH 2015
- Yoda has serial and SRAM working on his prototype. DRAM is being worked.
- NM156 has a populated and patched board with no successful testing so far
- The first set of erratas were posted (see section above)
Development Tools
- MiniGW for M68K - Binary GCC68k cross compiler distribution (Windows)
- EASy68K - Editor/Assembler/Simulator for the 68k. (Windows, but has been reported to run on Linux under Wine)
- GALASM - GAL assembler(Windows) is included in the GALS .zip file. The source is on GitHub if you are developing on a platform other than Windows
- EXTRAPutty - Terminal program
- BrayTerm - Diagnostic terminal program
- COM0COM - Virtual COM ports (Signed Windows 64bit driver) - great for running a real serial terminal with EASy68k
Software Resources
Reference Materials
Photo Gallery
| gryphon68030-1.00-addressdecode.pdf | 30.4 KiB | 2016/06/12 13:06 |
| gryphon68030-1.00-brd.pdf | 577.8 KiB | 2016/06/12 12:46 |
| gryphon68030-1.00-component-3dsfiles.zip | 4.7 MiB | 2016/06/12 13:15 |
| gryphon68030-1.00-erattabuildnotes.pdf | 31.8 KiB | 2016/06/12 13:31 |
| gryphon68030-1.00-erattapcb.pdf | 1.9 MiB | 2016/06/12 13:31 |
| gryphon68030-1.00-gals.zip | 60.7 KiB | 2016/06/12 13:27 |
| gryphon68030-1.00-gerb.zip | 1.1 MiB | 2016/06/12 12:44 |
| gryphon68030-1.00-proteus.zip | 375.3 KiB | 2016/06/12 13:10 |
| gryphon68030-1.00-sch.pdf | 147.3 KiB | 2016/06/12 12:46 |
| gryphon68030-1.00-software.zip | 33.5 KiB | 2016/06/12 13:31 |
| gryphon68030-1.10-sch.pdf | 149.7 KiB | 2016/06/12 12:48 |
| gryphon68030-3d.jpg | 493.6 KiB | 2016/06/12 12:54 |
| gryphon68030zofz.jpg | 658.8 KiB | 2016/06/12 12:54 |
| gryphon_68030-1.00-bom.pdf | 43.4 KiB | 2016/06/12 12:46 |
| hypnotoad-a.zip | 2.7 MiB | 2016/07/31 13:31 |
| other_mc68040_sbc_v2.zip | 2.8 MiB | 2016/07/30 11:04 |
