Special thanks to Andrew Lynch, Wayne Warthen, and John Coffman for their assistance with the design, development and testing of the DSKYng.
| BOARD | :boards:ecb:dskyng:nextgendsky_pcb.pdf |
| SCHEMATIC | :boards:ecb:dskyng:nextgendsky_schematic.pdf |
| GERBERS | :boards:ecb:dskyng:dskyng_gerber.zip |
| KICAD SOURCE | :boards:ecb:dskyng:nextgendsky.zip |
| ID | Quantity | Part Number | Notes |
| C1-9 | 9 | 0.1UF Unpolarized capacitor | |
| C10 | 1 | 22uf radial Tantalum | Optional – only needed for unregulated power input |
| C11 | 1 | 10uf radial electrolytic | Optional – only needed for unregulated power input |
| D1-24 | 32 | 3.0mm LED | |
| J1 | 1 | 2.54mm Pin Header 1×3 | |
| J2 | 1 | Barrel Jack | Optional – only needed for unregulated power input |
| J3-4 | 2 | 2.54mm Pin Header 2×13 | |
| J5 | 1 | 2.54mm Pin Header 1×3 | |
| J6 | 1 | 2.54mm Pin Header 2×12 | |
| J7-8 | 2 | 2.54mm Pin Header 2×20 | |
| J9 | 1 | 2.54mm Pin Header 1×2 | |
| Q1-6,Q11-16,Q21-24 | 16 | Transistor 2N3904 | |
| Q7-10,Q17-20 | 8 | Transistor 2N3906 | |
| R1 | 1 | 10K Resistor | |
| R2,R9-11,R18,21 | 8 | 22k Resistor | |
| R3-8,R12-17,R24-27 | 16 | 330 ohm Resistor | |
| SW1-30 | 30 | Cherry_MX Key Switch | any Cherry MX compatible keyswitch should work fine. |
| U1,U5,U16 | 3 | 74ACT138 | |
| U2 | 1 | 74LS00 | |
| U3,U6 | 2 | 74ACT240 | |
| U4 | 1 | intel 8279 | |
| U7-U16 | 8 | Display 7 Segment, CC, HDSP-7503 | |
| U15 | 1 | 74ACT244 | |
| U17 | 1 | 7805 | Optional – only needed for unregulated power input |
| X1 | 1 | Oscillator | 8279 can be configured to accept oscillators from 1 to 4Mhz |
| BZ1 | 1 | Piezo beeper | Note that an “active” piezo buzzer is required.* |
Keycap Sourcing Notes
Reasonable priced SA (almost uniform) profile shine-through key caps: https://www.amazon.com/gp/product/B082PJ26CG/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
low cost standard profile keys can be found here: https://flashquark.com/product-category/keycaps/oem-keys/mixable/|https://flashquark.com/product-category/keycaps/oem-keys/mixable/
low cost translucent keys can be found here, BUT these are not pre-printed: https://flashquark.com/product/translucent-dsa-keycaps/|https://flashquark.com/product/translucent-dsa-keycaps/
Software Documentation
; LED SEGMENTS (BIT VALUES) ; ; +--01--+ ; 20 02 ; +--40--+ ; 10 04 ; +--08--+ 80 ; ; KEY CODE MAP (KEY CODES) --CCCRRR ; ; 00 08 10 18 23 ; 01 09 11 19 22 ; 02 0A 12 1A 21 ; 03 0B 13 1B 20 ; 04 0C 14 1C SHIFT ; 05 0D 15 1D CTRL ; ; LED BIT MAP (BIT VALUES) ; ; $08 $09 $0A $0B $0C (Display Register) ; --- --- --- --- --- ; 01 01 01 01 01 ; 02 02 02 02 02 ; 04 04 04 04 04 ; 08 08 08 08 08 ; 10 10 10 10 10 ; 20 20 20 20 10 ; PPIA .EQU DSKYPPIBASE + 0 ; PORT A PPIB .EQU DSKYPPIBASE + 1 ; PORT B PPIC .EQU DSKYPPIBASE + 2 ; PORT C PPIX .EQU DSKYPPIBASE + 3 ; PPI CONTROL PORT ; DSKY_PPIX_RD: .EQU %10010010 ; PPIX VALUE FOR READS DSKY_PPIX_WR: .EQU %10000010 ; PPIX VALUE FOR WRITES ; ; PIO CHANNEL C: ; ; 7 6 5 4 3 2 1 0 ; RES 0 0 CS CS /RD /WR A0 ; ; SETTING BITS 3 & 4 WILL ASSERT /CS ON 3279 ; CLEAR BITS 1 OR 2 TO ASSERT READ/WRITE ; DSKY_PPI_IDLE: .EQU %00000110 ; DSKY_CMD_CLR: .EQU %11011111 ; CLEAR (ALL OFF) DSKY_CMD_CLRX: .EQU %11010011 ; CLEAR (ALL ON) DSKY_CMD_WDSP: .EQU %10010000 ; WRITE DISPLAY RAM DSKY_CMD_RDSP: .EQU %01110000 ; READ DISPLAY RAM DSKY_CMD_CLK: .EQU %00100000 ; SET CLK PRESCALE DSKY_CMD_FIFO: .EQU %01000000 ; READ FIFO ; DSKY_PRESCL: .EQU DSKYOSC/100000 ; PRESCALER
