Special thanks to Andrew Lynch, Wayne Warthen, and John Coffman for their assistance with the design, development and testing of the DSKYng.
IDQuantityPart NumberNotes
D1-24323.0mm LED
J112.54mm Pin Header 1×3
J3-422.54mm Pin Header 2×13
J512.54mm Pin Header 1×3
J612.54mm Pin Header 2×12
J7-822.54mm Pin Header 2×20
J912.54mm Pin Header 1×2
R1110K Resistor
R2,R9-11,R18,21822k Resistor
U1,U5,U16374ACT138
U2174LS00
U3,U6274ACT240
U41intel 8279
U15174ACT244
BZ11Piezo beeperNote that an “active” piezo buzzer is required.*
Keycap Sourcing Notes
Reasonable priced SA (uniform) profile shine-through key caps: https://www.amazon.com/gp/product/B082PJ26CG/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
low cost standard profile keys can be found here: https://flashquark.com/product-category/keycaps/oem-keys/mixable/
low cost DSA profile translucent keys can be found here, BUT these are not pre-printed.https://flashquark.com/product/translucent-dsa-keycaps/
Software Documentation
; LED SEGMENTS (BIT VALUES)
;       +--01--+
;       20    02
;       +--40--+
;       10    04
;       +--08--+  80
; KEY CODE MAP (KEY CODES) --CCCRRR
;       00      08      10      18      23
;       01      09      11      19      22
;       02      0A      12      1A      21
;       03      0B      13      1B      20
;       04      0C      14      1C      SHIFT
;       05      0D      15      1D      CTRL
; LED BIT MAP (BIT VALUES)
;       $08     $09     $0A     $0B     $0C   (Display Register)
;       01      01      01      01      01
;       02      02      02      02      02
;       04      04      04      04      04
;       08      08      08      08      08
;       10      10      10      10      10
;       20      20      20      20      10
PPIA            .EQU    DSKYPPIBASE + 0 ; PORT A
PPIB            .EQU    DSKYPPIBASE + 1 ; PORT B
PPIC            .EQU    DSKYPPIBASE + 2 ; PORT C
PPIX            .EQU    DSKYPPIBASE + 3 ; PPI CONTROL PORT
DSKY_PPIX_RD:   .EQU    %10010010       ; PPIX VALUE FOR READS
DSKY_PPIX_WR:   .EQU    %10000010       ; PPIX VALUE FOR WRITES
; PIO CHANNEL C:
;       7       6       5       4       3       2       1       0
;       RES     0       0       CS      CS      /RD     /WR     A0
; SETTING BITS 3 & 4 WILL ASSERT /CS ON 3279
; CLEAR BITS 1 OR 2 TO ASSERT READ/WRITE
DSKY_PPI_IDLE:  .EQU    %00000110
DSKY_CMD_CLR:   .EQU    %11011111       ; CLEAR (ALL OFF)
DSKY_CMD_CLRX:  .EQU    %11010011       ; CLEAR (ALL ON)
DSKY_CMD_WDSP:  .EQU    %10010000       ; WRITE DISPLAY RAM
DSKY_CMD_RDSP:  .EQU    %01110000       ; READ DISPLAY RAM
DSKY_CMD_CLK:   .EQU    %00100000       ; SET CLK PRESCALE
DSKY_CMD_FIFO:  .EQU    %01000000       ; READ FIFO
DSKY_PRESCL:    .EQU    DSKYOSC/100000  ; PRESCALER
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_boards_ecb_dskyng_front.jpgwww.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_boards_ecb_dskyng_back.jpg
boards/ecb/dskyng.1626225355.txt.gz · Last modified: 2021/07/13 21:15 by danwerner
