IDQuantityPart NumberNotes
D1-24323.0mm LED
J112.54mm Pin Header 1×3
J3-422.54mm Pin Header 2×13
J512.54mm Pin Header 1×3
J612.54mm Pin Header 2×12
J7-822.54mm Pin Header 2×20
J912.54mm Pin Header 1×2
R1110K Resistor
R2,R9-11,R18,21822k Resistor
U1,U5,U16374ACT138
U2174LS00
U3,U6274ACT240
U41intel 8279
U15174ACT244
BZ11Piezo beeperNote that an “active” piezo buzzer is required.*
Keycap Sourcing Notes
low cost standard profile keys can be found here: https://flashquark.com/product-category/keycaps/oem-keys/mixable/
low cost DSA profile translucent keys can be found here, BUT these are not pre-printed.https://flashquark.com/product/translucent-dsa-keycaps/
Software Documentation
Example code for using the DSKYng can be referenced from the RomWBW repo. Specifically /Source/HBIOS/dskyng.asm and /Source/Apps/tstdskng.asm will be useful in determining specifically how to write code for the DSKYng. The Intel 8279 datasheet is also a useful reference for the registers and functions of the 8279 display and keyboard driver.
boards/ecb/dskyng.1626199126.txt.gz · Last modified: 2021/07/13 13:58 by danwerner
