| BOARD | :boards:ecb:dskyng:nextgendsky_pcb.pdf |
| SCHEMATIC | :boards:ecb:dskyng:nextgendsky_schematic.pdf |
| GERBERS | :boards:ecb:dskyng:dskyng_gerber.zip |
| KICAD SOURCE | :boards:ecb:dskyng:nextgendsky.zip |
| ID | Quantity | Part Number | Notes |
| C1-9 | 9 | 0.1UF Unpolarized capacitor | |
| C10 | 1 | 22uf radial Tantalum | Optional – only needed for unregulated power input |
| C11 | 1 | 10uf radial electrolytic | Optional – only needed for unregulated power input |
| D1-24 | 32 | 3.0mm LED | |
| J1 | 1 | 2.54mm Pin Header 1×3 | |
| J2 | 1 | Barrel Jack | Optional – only needed for unregulated power input |
| J3-4 | 2 | 2.54mm Pin Header 2×13 | |
| J5 | 1 | 2.54mm Pin Header 1×3 | |
| J6 | 1 | 2.54mm Pin Header 2×12 | |
| J7-8 | 2 | 2.54mm Pin Header 2×20 | |
| J9 | 1 | 2.54mm Pin Header 1×2 | |
| Q1-6,Q11-16,Q21-24 | 16 | Transistor 2N3904 | |
| Q7-10,Q17-20 | 8 | Transistor 2N3906 | |
| R1 | 1 | 10K Resistor | |
| R2,R9-11,R18,21 | 8 | 22k Resistor | |
| R3-8,R12-17,R24-27 | 16 | 330 ohm Resistor | |
| SW1-30 | 30 | Cherry_MX Key Switch | any Cherry MX compatible keyswitch should work fine. |
| U1,U5,U16 | 3 | 74ACT138 | |
| U2 | 1 | 74LS00 | |
| U3,U6 | 2 | 74ACT240 | |
| U4 | 1 | intel 8279 | |
| U7-U16 | 8 | Display 7 Segment, CC, HDSP-7503 | |
| U15 | 1 | 74ACT244 | |
| U17 | 1 | 7805 | Optional – only needed for unregulated power input |
| X1 | 1 | Oscillator | 8279 can be configured to accept oscillators from 1 to 4Mhz |
| BZ1 | 1 | Piezo beeper | Note that an “active” piezo buzzer is required.* |
Keycap Sourcing Notes
low cost standard profile keys can be found here: https://flashquark.com/product-category/keycaps/oem-keys/mixable/
low cost DSA profile translucent keys can be found here, BUT these are not pre-printed.https://flashquark.com/product/translucent-dsa-keycaps/
Software Documentation
Photo Gallery
