IDQuantityPart NumberNotes
D1-24323.0mm LED
J112.54mm Pin Header 1×3
J3-422.54mm Pin Header 2×13
J512.54mm Pin Header 1×3
J612.54mm Pin Header 2×12
J7-822.54mm Pin Header 2×20
J912.54mm Pin Header 1×2
R1110K Resistor
R2,R9-11,R18,21822k Resistor
U1,U5,U16374ACT138
U2174LS00
U3,U6274ACT240
U41intel 8279
U15174ACT244
BZ11Piezo beeperNote that an “active” piezo buzzer is required. Example:(https://www.amazon.com/TOTOT-Electromagnetic-Continuously-Electronic-Components/dp/B07GJSP68S/ref=sr_1_3?crid=EO44N9WO16OJ&dchild=1&keywords=active+piezo+buzzer&qid=1626196358&sprefix=active+piez%2Caps%2C192&sr=8-3)
Part Sourcing Notes
Keypad Labels
Support Software
Video Demonstration
Builder's Notes/Comments
Software Documentation
boards/ecb/dskyng.1626197301.txt.gz · Last modified: 2021/07/13 13:28 by danwerner
