IDQuantityPart NumberNotes
C1-880.1UF Unpolarized capacitor
D1-24323.0mm LED
J112.54mm Pin Header 1×3
J2-322.54mm Pin Header 2×13
Q1-6,Q11-16,16Transistor 2N3904
8Transistor 2N3906
10K Resistor
22k Resistor
330 ohm Resistor
SW1-3030Cherry_MX Key Switch
U1,U5,U16374ACT138
U2174LS00
U3,U6274ACT240
U41intel 8279
U15174ACT244
Part Sourcing Notes
Keypad Labels
Support Software
Video Demonstration
Builder's Notes/Comments
Software Documentation
boards/ecb/dskyng.1626196171.txt.gz · Last modified: 2021/07/13 13:09 by danwerner
