builderpages:plasmo:smtsoldering [2017/04/17 17:51] plasmo |
builderpages:plasmo:smtsoldering [2017/04/27 19:27] (current) plasmo |
Line 7: | Line 7: | ||
- | The second version has generous long pads for the solder iron to preheat and room to apply solder to the pads so it will flow to wet the leads. This is the right SMT footprints for hand soldering. Note: it is hard to tell at this resolution, but the part on the left of picture below (the one that's soldered | + | The second version has generous long pads for the solder iron to preheat and room to apply solder to the pads so it will flow to wet the leads. This is the right SMT footprints for hand soldering. Note: it is hard to tell at this resolution, but the part on the left of picture below (the one that's soldered |
+ | Connect power and ground and JTAG programming header to two of the boards. | ||
