builderpages:plasmo:6502:cpld6502:cpld6502r1 [2022/05/18 23:35] plasmo |
builderpages:plasmo:6502:cpld6502:cpld6502r1 [2023/04/22 23:51] (current) plasmo |
==== Z80 Implementation ==== | ==== Z80 Implementation ==== |
{{:builderpages:plasmo:6502:cpld6502:z80_trainer_cpld_rev1pcb.zip|Z80 CPLD design file}} to run ROMWBW | Z80 implementation requires 14.7MHz oscillator, CMOS Z80, 512K RAM (e.g. AS6C4008), and 512K flash (e.g. SST39SF040) |
| [[https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=aff33c&media=https://www.retrobrewcomputers.org/lib/plugins/ckgedit/fckeditor/userfiles/image/builderpages/plasmo/6502/cpld6502/trainerwithz80.jpg|{{https://www.retrobrewcomputers.org/lib/plugins/ckgedit/fckeditor/userfiles/image/builderpages/plasmo/6502/cpld6502/trainerwithz80.jpg?direct&400x559|www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_6502_cpld6502_trainerwithz80.jpg}}]] |
| {{:builderpages:plasmo:6502:cpld6502:trainer_cpld_rev1pcb_z80_i2c.zip|Z80 CPLD design file}} to run ROMWBW <- updated release 6/5/22 with added I2C function |
| {{:builderpages:plasmo:6502:cpld6502:rcz80_trainer_z80_bit_bang_tx.zip|ROMWBW}} program for 512K boot flash such as SST39SF040 |
| {{:builderpages:plasmo:6502:cpld6502:life_gosper_gun_for_128x64oled_i2c_1.zip|Game of Life, Gosper gun}}. Require 128×64 OLED display installed on I2C connector (see picture below). Load .hex program with ROMWBW monitor and run from 0x1000. |
| [[https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=5512a9&media=https://www.retrobrewcomputers.org/lib/plugins/ckgedit/fckeditor/userfiles/image/builderpages/plasmo/6502/cpld6502/trainer_with_128x64oled_display_installedcopy_1.jpg|{{https://www.retrobrewcomputers.org/lib/plugins/ckgedit/fckeditor/userfiles/image/builderpages/plasmo/6502/cpld6502/trainer_with_128x64oled_display_installedcopy_1.jpg?direct&250x140|www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_6502_cpld6502_trainer_with_128x64oled_display_installedcopy_1.jpg}}]] |
| ==== 6502 Implementation ==== |
| 6502 implementation requires 7.37MHz oscillator, W65C02, 512K RAM (e.g. AS6C4008), and 512K flash (e.g. SST39SF040) |
| [[https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=2607dd&media=https://www.retrobrewcomputers.org/lib/plugins/ckgedit/fckeditor/userfiles/image/builderpages/plasmo/6502/cpld6502/trainerwith6502.jpg|{{https://www.retrobrewcomputers.org/lib/plugins/ckgedit/fckeditor/userfiles/image/builderpages/plasmo/6502/cpld6502/trainerwith6502.jpg?direct&400x520|www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_6502_cpld6502_trainerwith6502.jpg}}]] |
| 6502 CPLD design file |
| 6502 monitor |
| ===== Training Sessions ===== |
| Discussion about the CPLD6502 trainer can be found [[http://forum.6502.org/viewtopic.php?f=10&t=6974|here]]. The sessions were done with [[:builderpages:plasmo:6502:cpld6502:cpld6502r0|rev0]] of CPLD trainer; because of small differences between rev0 and rev1 design, some CPLD design files are updated to work with rev1 design. |
| Design files and software for the various sessions |
| Jan 27, 2022 ,[[http://forum.6502.org/viewtopic.php?f=10&t=6974&sid=a039497ff72fcc909848eb2e2785b9ab#p90404|Session 1]], Initial power up and first CPLD program. {{:builderpages:plasmo:6502:cpld6502:cpld_1st_test.zip|Session 1 CPLD design files}} |
| Jan 28, 2022, [[http://forum.6502.org/viewtopic.php?f=10&t=6974&sid=a039497ff72fcc909848eb2e2785b9ab#p90450|Session 2]], multiplexing 7-segment displays. {{:builderpages:plasmo:6502:cpld6502:cpld_7hz_7-seg_display_drive.zip|Session 2 CPLD design files}} |
| Jan 30, 2022, [[http://forum.6502.org/viewtopic.php?f=10&t=6974&sid=a039497ff72fcc909848eb2e2785b9ab#p90497|Session 3]], 6-digit 7-segment display. {{:builderpages:plasmo:6502:cpld6502:cpld_7-seg_display_counts.zip|Session 3 CPLD design files}} |
| Jan 31, 2022, [[http://forum.6502.org/viewtopic.php?f=10&t=6974&sid=a039497ff72fcc909848eb2e2785b9ab#p90535|Session 4]], lookup table and true 6-digit hex display. {{:builderpages:plasmo:6502:cpld6502:cpld_7-seg_hex_display.zip|Session 4 CPLD design files}} |
| Feb 1, 2022, [[http://forum.6502.org/viewtopic.php?f=10&t=6974&sid=a039497ff72fcc909848eb2e2785b9ab#p90564|Session 5]], 6502 NOP test. {{:builderpages:plasmo:6502:cpld6502:cpld_nop_test.zip|Session 5 CPLD design files}} |
| Feb 2, 2022, [[http://forum.6502.org/viewtopic.php?f=10&t=6974&sid=a039497ff72fcc909848eb2e2785b9ab#p90599|Session 6]], tester for 6502. {{:builderpages:plasmo:6502:cpld6502:cpld_rom_simpletx.zip|Session 6 CPLD design files}} |
| Feb 3, 2022, [[http://forum.6502.org/viewtopic.php?f=10&t=6974&sid=a039497ff72fcc909848eb2e2785b9ab#p90620|Session 7]], EPROM and RAM decode. Session 7 CPLD design files |
| Feb 4, 2022, [[http://forum.6502.org/viewtopic.php?f=10&t=6974&start=15#p90640|Session 8]], RAM diagnostic. RAM diagnostic source files |
| Feb 5, 2022, [[http://forum.6502.org/viewtopic.php?f=10&t=6974&start=15#p90670|Session 9]], 6502 SBC with serial port in CPLD. Session 9 CPLD design files |
| Feb 6, 2022, [[http://forum.6502.org/viewtopic.php?f=10&t=6974&start=15#p90680|Session 10]], Monitor for 6502 SBC. Session 10 CPLD design files, CPLD6502 SBC monitor software. |
| ===== Projects for 6502-based Trainer ===== |
| [[:builderpages:plasmo:6502:cpld6502:cpld6502r1:vga_beam_racing|VGA beam racing]] is a W65C02 overclocked to 25.175MHz, the 60Hz 640x480 VGA dot clock, such that 6502 fetch a byte every 8 clocks that's shifted out to VGA monitor at pixel clock rate. This results in monochrome 640x480 resolution images. |
| {{https://www.retrobrewcomputers.org/lib/plugins/ckgedit/fckeditor/userfiles/image/builderpages/plasmo/6502/cpld6502/6502trainerasvgacontroller.jpg?direct&300x190}} |
