boards:sbc:sbc_v2:sbc_v2-005 [2021/01/01 08:59]
b1ackmai1er [Acknowledgement]
boards:sbc:sbc_v2:sbc_v2-005 [2021/03/29 07:00] (current)
b1ackmai1er [SBC V2-005 MEGAFLASH]
Line 3: Line 3:
 The SBC V2 is a Zilog Z80 processor board. It's a 100x160mm board that is capable of functioning both as a standalone SBC or as attached to the ECB bus. The SBC V2 is a Zilog Z80 processor board. It's a 100x160mm board that is capable of functioning both as a standalone SBC or as attached to the ECB bus.
-The SBC V2-005 is currently under development. See [[:boards:sbc:sbc_v2:sbc_v2-005:development|here ]]for the current status.+The main advantage of this version over previous versions is the support of 1Mb FLASH memory and improved software support for Flash access.
-The main advantage of this version over previous versions is the support of 1Mb FLASH memory.+The SBC V2-005 is transitioning from development to releaseDevelopment history and additional supporting information can be found [[:boards:sbc:sbc_v2:sbc_v2-005:development|here ]]
Line 60: Line 60:
 Kicad files can be found [[https://github.com/b1ackmai1er/SBC-V2-005|here]] but may not be the most recent. Kicad files can be found [[https://github.com/b1ackmai1er/SBC-V2-005|here]] but may not be the most recent.
-Gerbers for SBC V2-005c {{:boards:sbc:sbc_v2:sbc_v2-005:sbc_v2-005c-gerbers.zip|here.}}+Gerbers for SBC V2-005c, which have been built and tested. {{:boards:sbc:sbc_v2:sbc_v2-005:sbc_v2-005c-gerbers.zip|here.}}
-Current revision is SBC V2-005f+Current revision is SBC V2-005i
 +Gerbers for SBC V2-005i, currently untested {{:boards:sbc:sbc_v2:sbc_v2-005:sbc_v2-005i-gerbers.zip|here.}}
 +Version i boards are on order as at 27-Feb-2021.
boards/sbc/sbc_v2/sbc_v2-005.1609509574.txt.gz · Last modified: 2021/01/01 08:59 by b1ackmai1er
