| Both sides previous revision Previous revision Next revision | Previous revision | ||
boards:sbc:sbc_v2:sbc_v2-005 [2020/12/23 09:21] b1ackmai1er [SBC V2-005 MEGAFLASH] |
boards:sbc:sbc_v2:sbc_v2-005 [2021/03/29 07:00] (current) b1ackmai1er [SBC V2-005 MEGAFLASH] |
| Line 3: | Line 3: | ||
| The SBC V2 is a Zilog Z80 processor board. It's a 100x160mm board that is capable of functioning both as a standalone SBC or as attached to the ECB bus. | The SBC V2 is a Zilog Z80 processor board. It's a 100x160mm board that is capable of functioning both as a standalone SBC or as attached to the ECB bus. | ||
| - | The SBC V2-005 | + | The main advantage of this version over previous versions |
| - | The main advantage of this version over previous versions | + | The SBC V2-005 |
| Line 60: | Line 60: | ||
| Kicad files can be found [[https:// | Kicad files can be found [[https:// | ||
| - | Gerbers for SBC V2-005c {{: | + | Gerbers for SBC V2-005c, which have been built and tested. |
| - | Current revision is SBC V2-005f | + | Current revision is SBC V2-005i |
| + | Gerbers for SBC V2-005i, currently untested {{: | ||
| + | Version i boards are on order as at 27-Feb-2021. | ||
| Line 73: | Line 77: | ||
| * Software support for programming dual chips. | * Software support for programming dual chips. | ||
| * Driver support for accessing ROM drive as a read and write filesystem. | * Driver support for accessing ROM drive as a read and write filesystem. | ||
| + | * ROMWBW based Flash upgrader. | ||
| + | * Solder link for UART clock as CPU clock for minimalist system. | ||
| Line 284: | Line 290: | ||
| ====== Acknowledgement ====== | ====== Acknowledgement ====== | ||
| - | The SBC V2-005 is based on the work of Andrew Lynch N8VEM and others in the Retrobrew Computers community. To see Andrew foundation work, see [[https:// | + | The SBC V2-005 is based on the work of Andrew Lynch N8VEM and others in the Retrobrew Computers community. To see Andrew' |
| Thank you Andrew! | Thank you Andrew! | ||
