boards:sbc:sbc_v2:minimum-build [2018/07/08 10:56] b1ackmai1er [Disk storage without ECB backplane and Disk I/O board.] |
boards:sbc:sbc_v2:minimum-build [2019/06/10 11:10] (current) b1ackmai1er [Use flash memory instead of UV-erasable EPROM] |
Line 33: | Line 33: | ||
* X1 (32768 Hz crystal) | * X1 (32768 Hz crystal) | ||
* C9 (bypass capacitor) | * C9 (bypass capacitor) | ||
===== NVRAM Controller ===== | ===== NVRAM Controller ===== | ||
Line 48: | Line 47: | ||
* U22 (Max232) | * U22 (Max232) | ||
* C24-C28 (1uF capacitors) | * C24-C28 (1uF capacitors) | ||
- | * Bridge | + | * Bridge |
+ | * Bridge pins 14-11 and 13-12 in the Max232 component position if hardware flow control is required. | ||
Examples of minimum connections required: | Examples of minimum connections required: | ||
Line 58: | Line 58: | ||
{{https:// | {{https:// | ||
===== Component Substitution ===== | ===== Component Substitution ===== | ||
Line 65: | Line 63: | ||
==== Use flash memory instead of UV-erasable EPROM ==== | ==== Use flash memory instead of UV-erasable EPROM ==== | ||
- | Flash memory is generally cheaper, easier to obtain, and easier to work with. It could be instantly erased, without UV eraser lamp, it doesn' | + | Flash memory is generally cheaper, easier to obtain, and easier to work with. It can be instantly erased, without UV eraser lamp, it doesn' |
^Device - Jumper^Size^K1^K6^K8| | ^Device - Jumper^Size^K1^K6^K8| | ||
^AT29C020^256Kb|1-2|2-3|None| | ^AT29C020^256Kb|1-2|2-3|None| | ||
+ | ^AM29F040B^512Kb|1-2|2-3|2-3| | ||
+ | ^AT49F040A^512Kb|1-2|2-3|2-3| | ||
+ | ^SST39SF040^512Kb|1-2|2-3|2-3| | ||
+ | ^M27C4001^512Kb|1-2|1-2|None| | ||
^AT27C080^1Mb|1-2|1-2|1-2| | ^AT27C080^1Mb|1-2|1-2|1-2| | ||
^M27C801^1Mb|1-2|1-2|1-2| | ^M27C801^1Mb|1-2|1-2|1-2| | ||
+ | In the situation that you do not have an EPROM programmer it is best to obtain a copy of the ROMWBW in a FLASH format so it can be reprogrammed in-system using the FLASH utility. A HOTFLASH technique can be used if you want to swap from an EPROM to a FLASH chip without an EPROM programmer: | ||
+ | Example starting with an AT27C080 EPROM and swapping to a AT49F040A FLASH chip. | ||
+ | - Transfer new ROM image from PC to SBC-V2 secondary storage i.e. SDCard | ||
+ | - Copy FLASH.COM from B: to secondary storage i.e SDCard | ||
+ | - Change to secondary storage directory. | ||
+ | - Remove EPROM | ||
+ | - Change jumpers to suit FLASH chip i.e. K1 unchanged, K6 from 1-2 to 2-3, K8 from 1-2 to 2-3. | ||
+ | - Insert FLASH chip. Insert pin 1 side first to ensure GND had contact first. | ||
+ | - Run FLASH.COM i.e. FLASH /WRITE SBC.ROM | ||
+ | - Reboot | ||
Line 85: | Line 100: | ||
==== Disk storage without ECB backplane and Disk I/O board. ==== | ==== Disk storage without ECB backplane and Disk I/O board. ==== | ||
- | You can install the 8255 PPI chip, and use the [[https:// | + | You can install the 8255 PPI chip, and use the [[:boards: |
+ | {{https:// | ||
