boards:sbc:sbc_v2:minimum-build [2018/07/08 10:51] b1ackmai1er [Crystals and Oscillators.] |
boards:sbc:sbc_v2:minimum-build [2019/06/10 11:10] (current) b1ackmai1er [Use flash memory instead of UV-erasable EPROM] |
Line 27: | Line 27: | ||
===== Real Time Clock ===== | ===== Real Time Clock ===== | ||
- | ECB SBC board features Dallas DS1302 Real Time Clock. It can be used for time keeping and also it has a few bytes non-volatile memory (NVRAM), that could be used for example, for storing system configuration. Currently (Jan 2012) BIOS doesn' | + | ECB SBC board features Dallas DS1302 Real Time Clock. It can be used for time keeping and also it has a few bytes non-volatile memory (NVRAM), that could be used for example, for storing system configuration. |
* U18 (74LS174) | * U18 (74LS174) | ||
Line 47: | Line 47: | ||
* U22 (Max232) | * U22 (Max232) | ||
* C24-C28 (1uF capacitors) | * C24-C28 (1uF capacitors) | ||
- | * Bridge | + | * Bridge |
+ | * Bridge pins 14-11 and 13-12 in the Max232 component position if hardware flow control is required. | ||
Examples of minimum connections required: | Examples of minimum connections required: | ||
Line 57: | Line 58: | ||
{{https:// | {{https:// | ||
===== Component Substitution ===== | ===== Component Substitution ===== | ||
Line 64: | Line 63: | ||
==== Use flash memory instead of UV-erasable EPROM ==== | ==== Use flash memory instead of UV-erasable EPROM ==== | ||
- | Flash memory is generally cheaper, easier to obtain, and easier to work with. It could be instantly erased, without UV eraser lamp, it doesn' | + | Flash memory is generally cheaper, easier to obtain, and easier to work with. It can be instantly erased, without UV eraser lamp, it doesn' |
^Device - Jumper^Size^K1^K6^K8| | ^Device - Jumper^Size^K1^K6^K8| | ||
^AT29C020^256Kb|1-2|2-3|None| | ^AT29C020^256Kb|1-2|2-3|None| | ||
+ | ^AM29F040B^512Kb|1-2|2-3|2-3| | ||
+ | ^AT49F040A^512Kb|1-2|2-3|2-3| | ||
+ | ^SST39SF040^512Kb|1-2|2-3|2-3| | ||
+ | ^M27C4001^512Kb|1-2|1-2|None| | ||
^AT27C080^1Mb|1-2|1-2|1-2| | ^AT27C080^1Mb|1-2|1-2|1-2| | ||
^M27C801^1Mb|1-2|1-2|1-2| | ^M27C801^1Mb|1-2|1-2|1-2| | ||
+ | In the situation that you do not have an EPROM programmer it is best to obtain a copy of the ROMWBW in a FLASH format so it can be reprogrammed in-system using the FLASH utility. A HOTFLASH technique can be used if you want to swap from an EPROM to a FLASH chip without an EPROM programmer: | ||
+ | Example starting with an AT27C080 EPROM and swapping to a AT49F040A FLASH chip. | ||
+ | - Transfer new ROM image from PC to SBC-V2 secondary storage i.e. SDCard | ||
+ | - Copy FLASH.COM from B: to secondary storage i.e SDCard | ||
+ | - Change to secondary storage directory. | ||
+ | - Remove EPROM | ||
+ | - Change jumpers to suit FLASH chip i.e. K1 unchanged, K6 from 1-2 to 2-3, K8 from 1-2 to 2-3. | ||
+ | - Insert FLASH chip. Insert pin 1 side first to ensure GND had contact first. | ||
+ | - Run FLASH.COM i.e. FLASH /WRITE SBC.ROM | ||
+ | - Reboot | ||
Line 84: | Line 100: | ||
==== Disk storage without ECB backplane and Disk I/O board. ==== | ==== Disk storage without ECB backplane and Disk I/O board. ==== | ||
- | You can install the 8255 PPI chip, and use the [[https:// | + | You can install the 8255 PPI chip, and use the [[:boards: |
+ | {{https:// | ||
- | ==== Use CMOS 74HCT or 74AHCT ICs instead of the TTL 74LS ==== | ||
- | CMOS 74HCT and 74AHCT logic ICs are usually cheaper than corresponding TTL ICs. They are also consume significantly less electricity. Note that some people reported problems with using these parts for ECB buffers / transmitters and also in SBC-188 (particularly using 74HCT373/ | ||
- | ==== Use MAX232 alternative. ==== | ||
- | The original MAX232 or MAX232A parts can be expensive. Other vendors make compatible parts, that are significantly cheaper. For example Texas Instruments TRS202, or Intersil HIN232. These parts can also work with 0.1 uF capacitors (smaller, cheaper, you'll be buying them for bypass capacitors anyway). | ||
- | ==== Disk storage without ECB backplane and Disk I/O board. ==== | ||
- | You can install the 8255 PPI chip, and use the [[https:// | ||
===== Crystals and Oscillators. ===== | ===== Crystals and Oscillators. ===== |
