| Both sides previous revision Previous revision Next revision | Previous revision | ||
boards:ecb:dskyng [2021/07/13 13:26] danwerner |
boards:ecb:dskyng [2021/07/14 10:24] (current) danwerner [Software Documentation] |
| Line 8: | Line 8: | ||
| The DSKYng provides a low-level interface to the hardware on the RBC Z80 SBC (and others). This Intel 8279 based display and keyboard provides a simple to program buffered keyboard and display for simple tasks. It is supported by the monitor in RomWBW allowing the user can inspect/ | The DSKYng provides a low-level interface to the hardware on the RBC Z80 SBC (and others). This Intel 8279 based display and keyboard provides a simple to program buffered keyboard and display for simple tasks. It is supported by the monitor in RomWBW allowing the user can inspect/ | ||
| + | Special thanks to Andrew Lynch, Wayne Warthen, and John Coffman for their assistance with the design, development and testing of the DSKYng. | ||
| ===== Hardware Documentation ===== | ===== Hardware Documentation ===== | ||
| Line 24: | Line 26: | ||
| * IO Bus (Jumper J1 1&2 Shorted) | * IO Bus (Jumper J1 1&2 Shorted) | ||
| - | * Directly with regulated 5v (Jumper J1 pins 2 & 3) | + | * Directly with regulated 5v (Jumper J1, apply power to pins 2 & 3) |
| * Directly with unregulated 7-9V (unregulated power connector . . requires optional power regulator components) | * Directly with unregulated 7-9V (unregulated power connector . . requires optional power regulator components) | ||
| Line 44: | Line 46: | ||
| |J2|1|Barrel Jack|Optional – only needed for unregulated power input| | |J2|1|Barrel Jack|Optional – only needed for unregulated power input| | ||
| |J3-4|2|2.54mm Pin Header 2×13| | |J3-4|2|2.54mm Pin Header 2×13| | ||
| - | |J5|1| | | | + | |J5|1|2.54mm Pin Header 1×3| | |
| + | |J6|1|2.54mm Pin Header 2×12| | | ||
| + | |J7-8|2|2.54mm Pin Header 2×20| | | ||
| + | |J9|1|2.54mm Pin Header 1×2| | | ||
| |Q1-6, | |Q1-6, | ||
| |Q7-10, | |Q7-10, | ||
| Line 59: | Line 64: | ||
| |U17|1|7805|Optional – only needed for unregulated power input| | |U17|1|7805|Optional – only needed for unregulated power input| | ||
| |X1|1|Oscillator|8279 can be configured to accept oscillators from 1 to 4Mhz| | |X1|1|Oscillator|8279 can be configured to accept oscillators from 1 to 4Mhz| | ||
| - | |BZ1|1|Piezo beeper|Note that an " | + | |BZ1|1|Piezo beeper|Note that an " |
| - | ==== Part Sourcing Notes ==== | + | *(a buzzer such as the one here [[https:// |
| - | Keypad Labels | + | ==== Keycap Sourcing Notes ==== |
| - | Support Software | + | Because the key are not in a " |
| - | Video Demonstration | + | Reasonable priced SA (almost uniform) profile shine-through key caps: [[https:// |
| - | Builder' | + | low cost standard profile keys can be found here: [[https:// |
| - | Please use this space to add any notes/ | + | low cost translucent keys can be found here, BUT these are not pre-printed: |
| ===== Software Documentation ===== | ===== Software Documentation ===== | ||
| - | ===== Photo Gallery ===== | + | Example code for using the DSKYng can be referenced from the RomWBW repo. Specifically / |
| + | ; LED SEGMENTS (BIT VALUES) | ||
| + | ; KEY CODE MAP (KEY CODES) --CCCRRR | ||
| + | ; LED BIT MAP (BIT VALUES) | ||
| + | ; $08 $09 $0A $0B $0C $0D $0E $0F | ||
| + | ; 01 | ||
| + | ; 02 | ||
| + | ; 04 | ||
| + | ; 08 | ||
| + | ; 10 | ||
| + | ; 20 | ||
| + | PPIA .EQU DSKYPPIBASE + 0 ; PORT A | ||
| + | PPIB .EQU DSKYPPIBASE + 1 ; PORT B | ||
| + | PPIC .EQU DSKYPPIBASE + 2 ; PORT C | ||
| + | PPIX .EQU DSKYPPIBASE + 3 ; PPI CONTROL PORT | ||
| + | DSKY_PPIX_RD: | ||
| + | DSKY_PPIX_WR: | ||
| + | ; PIO CHANNEL C: | ||
| + | ; SETTING BITS 3 & 4 WILL ASSERT /CS ON 3279 | ||
| + | ; CLEAR BITS 1 OR 2 TO ASSERT READ/ | ||
| + | DSKY_PPI_IDLE: | ||
| + | DSKY_CMD_CLR: | ||
| + | DSKY_CMD_CLRX: | ||
| + | DSKY_CMD_WDSP: | ||
| + | DSKY_CMD_RDSP: | ||
| + | DSKY_CMD_CLK: | ||
| + | DSKY_CMD_FIFO: | ||
| - | File List | + | DSKY_PRESCL: |
| - | \\ | + | [[https:// |
