Atmel and Altera CPLD Compatibility Notes
Overview & Part Numbers
There was a question about it if would be possible to use Altera CPLDs in the S100Computers.com CLPD 386 board, instead of the as-designed Atmel CPLD.
Datasheet for the ATMEL ATF1508AS/ATF1508ASL
Datasheet for the Altera MAX 7000
Note that the orginal part specificed is ATF1508AS-10JU84, which is a part with 128 macrocells, and a 10ns t(pd) (125 mhz max) in an 84pin PLCC package.
The corresponding Altera part would be an EPM7128SLC84-10N. Here are the relevant pin diagrams from the two datasheets:
The only major difference between the two appears to be that the ATF1508 part has as GCKL3 pin, which is not present on the MAX7000S part. Otherwise based on the overall datasheets, the parts appear to be pin-compatible.
The implementation provided by John M. is written in WinCUPL for the ATF1508. To use an alternate Atmel part, a VHDL or Verilog implementation of the logic equations would be required and would likely need to be provided by the board builder.
Hardware Cost Comparison
Note - if comparing the cost of *new* hardware for these two systems, the Atmel hardware is less expensive than the Altera hardware.
Altera MAX 7000S CPLDs may be purchased from UTSource.com in China. There are many $10 Altera USB Blaster clones on eBay, but they may not be 100% reliable. Buying an eBay programmer and chips from UTsource brings the cost down to less than the cost of the ATMEL parts, but possibly at the cost of reliability of the setup.
Development Software Comparison
builderpages/abingham/cpld-compatibility.1451265186.txt.gz · Last modified: 2015/12/27 20:13 by admin
