The following information described details of previous versions
Version 1
In version 1 the Zilog peripheral board header layouts are different to the other boards in the ECB and are shown below. Custom cables must be made. For example - the Z80-DART/SIO doesn't provide a DSR input so it uses DCD instead. Ring Indicator is also not used.
Version 2 aligns the board with standard IBM PC standard.
| X3 / X7 pin | Signal | DB-9M | DB-9F | Note |
| 1 | GND | 5 | 5 | |
| 2 | GND | 5 | 5 | |
| 3 | /Tx out | 3 | 2 | |
| 4 | DCD in | 6 / 1 | 4 | |
| 5 | /Rx in | 2 | 3 | |
| 6 | DTR out | 4 | 6 / 1 | |
| 7 | RST out | 7 | 8 | |
| 8 | n/c | n/c | n/c | |
| 9 | CTS in | 8 | 7 | |
| 10 | n/c | n/c | n/c |
