KISS-68030 board 1.0 & 1.1
Files
| Filename | Size | Modified |
| KISS-68030-1.0-005-schematic.pdf | 521.1 Kb | 2015-06-21 |
| KISS-68030-1.0-005-board.pdf | 1.6 Mb | 2015-10-30 |
| KISS-68030-parts-list.pdf | 29.8 Kb | 2015-09-05 |
| KISS-68030-1.0-005-layout (PNG) | 105.4 Kb | 2015-10-30 |
| Update-KISS-version-1.0-to-1.1.pdf | 20.3 Kb | 2015-08-15 |
| KISS-68030-1.1-PLD-jed-GAL3.zip | 6.1 Kb | 2015-08-15 |
| kiss68030-kicad-006.zip | 4.4 Mb | 2017-03-08 |
Memory Tests
In bringing up a new board pair (KISS-68030 and MF/PIC), the first test to run is a memory test. The binary distribution below contains TEST3.BIN and TEST4.BIN, which you should burn to ROM depending upon the size of the memory SIMMs you are using. Output is first to the LEDs on the KISS-68030 CPU board, then to a terminal at 9600bps, 8 bits, no parity, 1 or 2 stop bits. More information about the tests, as well as older TEST1.BIN and TEST2.BIN, are contained in the README file.
The MF/PIC board should be set to I/O address 0x40. The board must be updated to version 1.1.
| test15-bin.zip | 18.4Kb | 2016-03-12 |
| test15-src.zip | 93.6Kb | 2016-03-12 |
| test14.zip (archive) | 40Kb | 2015-09-06 |
