ECB-4PIO-I2C Development
  • 4 Zilog PIO's.
  • 8 i/o ports on 4 headers.
  • Full Z80 interrupt mode 2 support.
  • Correction for inverted ground and power plane.
  • PCF8584 I2C controller.
  • Two I2C pin header connector.
  • Reset pin header connector.
  • On board socket for 24LC512 flash.
  • Onboard socket for DS1307 RTC with battery connection header.
  • Jumpers to connect PCF8584 and DS1307 outputs to PIO #3
  • Additional power and ground connectors to i/o port headers.
Status:
  • Untested, boards ordered 28-Feb-2021
  • Board received (I2Cb), construction and testing commenced.
    • There are some missing silkscreen details. Corrected on version c
    • IC7 inputs (pin 2-3, 13-14) are swapped due to Kicad symbols changes. Corrected on version c
    • IC16 pin 18 should be connected to VCC not GND for correct address decoding. Corrected on version c
    • Pullups R9, R10, R11 changed from 4K7 to 1K. Corrected in version C
    • Reset connector P8 is effectively connected to /M1 not RESET.. Corrected in version c
    • /RST on PCF8584 is connect to /M1 not /RESET. Corrected in version c
    • CE-PIO1 & CE-PIO2 were swapped. Corrected in version c
    • First I2C bus output seen 17/4/2021! … but doesn't do anything yet.
    • Added pin description on silkscreen.
    • Successfully read data off 24LC512.
    • Removed /WR qualification on IC15
    • Allow more space for crystal, shrouded port connectors.
    • Change top layer to vcc plane for better power distribution.
    • Gate /WR with /CS to meet PCF8584 Z80 configuration requirements.
    • Version C committed including above changes
  • 4PIO-I2Cd
    • Component placement, routing changes.
    • Initial ROMWBW HBIOS support.
    • Add jumper to connect DS1307 battery backup to backplane battery backup.
Board
I/O Addressing
AB7AB6AB5AB4
OFFONONOFF
1010
AB7AB6AB5AB4AB3AB2AB1
ONONONONOFFOFFOFF
1111000
I2C Addressing
AT25LC512
24LC512DEFAULTALTERNATE
READ10100001 (A1)10100111 (A7)
WRITE10100000 (A0)10100110 (A6)
DS1307
DS1307DEFAULT
READ11010000 (D0)
WRITE11010001 (D1)
PCF8574 > LCD backpack
PCF8574DEFAULT
READ01001111 (4F)
WRITE01001110 (4E)
Software & Drivers
ROMWBW
RomWBW HBIOS v3.1.1-pre.75, 2021-05-12
SBC Z80 @ 12.000MHz
0 MEM W/S, 1 I/O W/S, INT MODE 2, SBC MMU
512KB ROM, 512KB RAM
UART0: IO=0x68 16550A MODE=38400,8,N,1
I2C: IO=0xF0
DS1307: 01/01/21 00:00:01
TMS: IO=0x98 NOT PRESENT
MD: FLASH=1 1=29F040 FLASH FILE SYSTEM DISABLED
MD: UNITS=2 ROMDISK=384KB RAMDISK=256KB
FD: IO=0x36 UNITS=2
RF: IO=0xA0 WP=OFF IO=0xA4 WP=OFF DEVICES=2
PPIDE: IO=0x60
PPIDE0: LBA BLOCKS=0x003DFC20 SIZE=1983MB
PPIDE1: NO MEDIA
PPIDE: IO=0x20 PPI NOT PRESENT
PPIDE: IO=0x44 PPI NOT PRESENT
Utilities
RTCHB - display date and time using HBIOS functions
H>rtchb
01/01/21 00:03:19
RTCDS7 - display date and time using direct access through PCF8584.
H>rtcds7
01/01/21 00:03:35
References
Key Learnings
  • Black solder mask PCBs are terrible for development debugging. Very hard to see traces.
  • Size of pullup resistors is important on open collector outputs. There is a huge difference in rise time between 1K and 4K7 pullups.
  • Make provisions for I2C device and bus timeouts to avoid lockups.
  • Do a hard reset between each software test to ensure consistent results. Exiting in a known state is important.
  • Software control of hard reset is desirable as soft reset does guarantee consistent results.
boards/ecb/4pio-i2c/development.1620822479.txt.gz · Last modified: 2021/05/12 08:27 by b1ackmai1er
