ECB-4PIO-I2C Development
- 4 Zilog PIO's.
- 8 i/o ports on 4 headers.
- Full Z80 interrupt mode 2 support.
- Correction for inverted ground and power plane.
- PCF8584 I2C controller.
- Two I2C pin header connector.
- Reset pin header connector.
- On board socket for 24LC512 flash.
- Onboard socket for DS1307 RTC with battery connection header.
- Jumpers to connect PCF8584 and DS1307 outputs to PIO #3
- Additional power and ground connectors to i/o port headers.
Status:
Untested, boards ordered 28-Feb-2021- Board received (I2Cb), construction and testing commenced.
- There are some missing silkscreen details. Corrected on version c
- IC7 inputs (pin 2-3, 13-14) are swapped due to Kicad symbols changes. Corrected on version c
- IC16 pin 18 should be connected to VCC not GND for correct address decoding. Corrected on version c
- Pullups R9, R10, R11 changed from 4K7 to 1K. Corrected in version C
- Reset connector P8 is effectively connected to /M1 not RESET.. Corrected in version c
- /RST on PCF8584 is connect to /M1 not /RESET. Corrected in version c
- CE-PIO1 & CE-PIO2 were swapped. Corrected in version c
- First I2C bus output seen 17/4/2021! … but doesn't do anything yet.
- Added pin description on silkscreen.
- Successfully read data off 24LC512.
Removed /WR qualification on IC15- Allow more space for crystal, shrouded port connectors.
- Change top layer to vcc plane for better power distribution.
- Gate /WR with /CS to meet PCF8584 Z80 configuration requirements.
- Version C committed including above changes
- 4PIO-I2Cd
- Component placement, routing changes.
Board
I/O Addressing
AB7 | AB6 | AB5 | AB4 |
OFF | ON | ON | OFF |
1 | 0 | 1 | 0 |
AB7 | AB6 | AB5 | AB4 | AB3 | AB2 | AB1 |
ON | ON | ON | ON | OFF | OFF | OFF |
1 | 1 | 1 | 1 | 0 | 0 | 0 |
I2C Addressing
24LC512 | DEFAULT | ALTERNATE |
READ | 10100001 (A1) | 10100111 (A7) |
WRITE | 10100000 (A0) | 10100110 (A6) |
DS1307 | DEFAULT |
READ | 11010000 (D0) |
WRITE | 11010001 (D1) |
PCF8574 | DEFAULT |
READ | 01001111 (4F) |
WRITE | 01001110 (4E) |
References
Sample test code: https://www.eevblog.com/forum/projects/z80lt-gtpcf8584-i2c-interface-problem/
I2C driver code: https://github.com/ncb85/utilis-and-examples/tree/master/cpm_i2c
6809 Interface: https://www.aslak.net/index.php/2013/07/18/i2c-on-a-6809-computer-and-a-mini-review-of-a-logic-analyser/
Understanding the I2C Bus - Texas Instruments: https://www.ti.com/lit/an/slva704/slva704.pdf
Linux C driver: https://code.woboq.org/linux/linux/drivers/i2c/algos/i2c-algo-pcf.c.html
Key Learnings
- Black solder mask PCBs are terrible for development debugging. Very hard to see traces.
- Size of pullup resistors is important on open collector outputs. There is a huge difference in rise time between 1K and 4K7 pullups.
- Make provisions for I2C device and bus timeouts to avoid lockups.
- Do a hard reset between each software test to ensure consistent results. Exiting in a known state is important.
- Software control of hard reset is desirable as soft reset does guarantee consistent results.
