ECB-4PIO-I2C Development
  • 4 Zilog PIO's.
  • 8 i/o ports on 4 headers.
  • Full Z80 interrupt mode 2 support.
  • Correction for inverted ground and power plane.
  • PCF8584 I2C controller.
  • Two I2C pin header connector.
  • Reset pin header connector.
  • On board socket for 24LC512 flash.
  • Onboard socket for DS1307 RTC with battery connection header.
  • Jumpers to connect PCF8584 and DS1307 outputs to PIO #3
  • Additional power and ground connectors to i/o port headers.
Status:
  • Untested, boards ordered 28-Feb-2021
  • Board received (I2Cb), construction and testing commenced.
    • There are some missing silkscreen details. Corrected on version c
    • IC7 inputs (pin 2-3, 13-14) are swapped due to Kicad symbols changes. Corrected on version c
    • IC16 pin 18 should be connected to VCC not GND for correct address decoding. Corrected on version c
    • Pullups R9, R10, R11 changed from 4K7 to 1K. Corrected in version C
    • Reset connector P8 is effectively connected to /M1 not RESET.. Corrected in version c
    • /RST on PCF8584 is connect to /M1 not /RESET. Corrected in version c
    • CE-PIO1 & CE-PIO2 were swapped. Corrected in version c
    • First I2C bus output seen 17/4/2021! … but doesn't do anything yet.
    • Added pin description on silkscreen.
    • Successfully read data off 24LC512.
    • Removed /WR qualification on IC15
    • Allow more space for crystal, shrouded port connectors.
    • Change top layer to vcc plane for better power distribution.
    • Gate /WR with /CS to meet PCF8584 Z80 configuration requirements.
    • Version C committed including above changes
  • 4PIO-I2Cd
    • Component placement, routing changes.
Board
I/O Addressing
AB7AB6AB5AB4
OFFONONOFF
1010
AB7AB6AB5AB4AB3AB2AB1
ONONONONOFFOFFOFF
1111000
I2C Addressing
AT25LC512
24LC512DEFAULTALTERNATE
READ10100001 (A1)10100111 (A7)
WRITE10100000 (A0)10100110 (A6)
DS1307
DS1307DEFAULT
READ11010000 (D0)
WRITE11010001 (D1)
PCF8574 > LCD backpack
PCF8574DEFAULT
READ01001111 (4F)
WRITE01001110 (4E)
References
Key Learnings
  • Black solder mask PCBs are terrible for development debugging. Very hard to see traces.
  • Size of pullup resistors is important on open collector outputs. There is a huge difference in rise time between 1K and 4K7 pullups.
  • Make provisions for I2C device and bus timeouts to avoid lockups.
  • Do a hard reset between each software test to ensure consistent results. Exiting in a known state is important.
  • Software control of hard reset is desirable as soft reset does guarantee consistent results.
boards/ecb/4pio-i2c/development.1619416409.txt.gz · Last modified: 2021/04/26 01:53 by b1ackmai1er
