buildtips:components_compatibility_and_substitution [2015/10/31 02:33] martin8bity |
buildtips:components_compatibility_and_substitution [2016/07/06 00:09] (current) davidcary mention other possible substitutions? |
Line 39: | Line 39: | ||
The 74F series, originally introduced by Fairchild Semiconductor, | The 74F series, originally introduced by Fairchild Semiconductor, | ||
- | ==== <font inherit/ | + | ==== ** 74AS - Advanced Schottky TTL ** ==== |
This series was introduced as an alternative to 74F logic. Just as 74ALS was a lower power version of 74LS logic, 74AS is a lower power version of 74S logic. | This series was introduced as an alternative to 74F logic. Just as 74ALS was a lower power version of 74LS logic, 74AS is a lower power version of 74S logic. | ||
Line 47: | Line 47: | ||
74ALS lowers power requirements, | 74ALS lowers power requirements, | ||
- | One caution: 74LS is often the only family with hysteresis on bus <font inherit/ | + | One caution: 74LS is often the only family with hysteresis on bus receiver inputs. This makes 74LS14, 74LS132, 74LS240, 74LS244, 74LS245, 74LS682, and 74LS688 the preferred chips for bus receivers. As drivers, any of the above may be substituted. One exception to this rule is 74ALS14 – it has hysteresis on its inputs. |
- | However, the N8VEM ECB bus seems <font inherit/ | + | However, the N8VEM ECB bus seems not to suffer from noise problems, and I have not heard of anyone having problems with substitutions for bus receivers. |
===== CMOS (Complementary Metal-Oxide-Semiconductor) Logic ===== | ===== CMOS (Complementary Metal-Oxide-Semiconductor) Logic ===== | ||
Line 77: | Line 77: | ||
* 74LS Series bus drivers and transceivers, | * 74LS Series bus drivers and transceivers, | ||
+ | ====== Programmable logic device ICs ====== | ||
+ | ===== Simple programmable logic devices ===== | ||
+ | PAL, PLA, PLD, SPLD, etc. | ||
+ | Alas, many of them are one-time programmable. | ||
+ | Can the erasable-and-reprogrammable GAL and EEPLD devices be programmed to be backwards compatible? | ||
+ | ===== CPLD ===== | ||
+ | "Atmel and Altera CPLD Compatibility Notes" ([[builderpages: | ||
====== ASICs (Z80, Intel 8xxx, UART) ====== | ====== ASICs (Z80, Intel 8xxx, UART) ====== | ||
Line 105: | Line 118: | ||
* Maxim MAX232ACP (either 0.1 uF or 1 uF capacitors) | * Maxim MAX232ACP (either 0.1 uF or 1 uF capacitors) | ||
* Texas Instruments TRS202ECN (0.1 uF capacitors) | * Texas Instruments TRS202ECN (0.1 uF capacitors) | ||
+ | * STMicroelectronics ST232CN/BN (either 0.1 uF or 1 uF capacitors) | ||
+ | * Maxim MAX3232CPE (3×0.33 uF + 1×0.047 uF capacitors for 5.0V power or 4×0.1 uF for 3.3V) | ||
====== Passive Components ====== | ====== Passive Components ====== | ||
Line 140: | Line 155: | ||
[[http:// | [[http:// | ||
