| Both sides previous revision Previous revision Next revision | Previous revision | ||
builderpages:robg:pdp10x [2020/01/27 09:25] robg |
builderpages:robg:pdp10x [2020/01/27 16:17] (current) robg |
| Line 54: | Line 54: | ||
| The board uses a standard 5V/2A wall-wart DC power supply with | The board uses a standard 5V/2A wall-wart DC power supply with | ||
| a 5.5mmx2.1mm connector jack. | a 5.5mmx2.1mm connector jack. | ||
| + | ==== Schematics and Build Files ==== | ||
| + | My board, schematics, layout files and code changes are made available under the [[https:// | ||
| + | ^ Item ^ File ^ | ||
| + | | Schematics | {{pdp10x_v01_schematic.pdf}} | | ||
| + | | Manufacturing Files (Gerbers) | {{pdp10x_v01.zip}} | | ||
| + | | KiCad Files | On GitLab: [[https:// | ||
| ==== Acknowledgements and Licenses ==== | ==== Acknowledgements and Licenses ==== | ||
| Line 68: | Line 77: | ||
| Thanks to Jose Luis Collado ([[https:// | Thanks to Jose Luis Collado ([[https:// | ||
| - | My board, | + | (If there is no license mentioned for the above works, it's because I could not find one. Please send corrections.) |
| + | ==== Bill of Materials (BOM) ==== | ||
| + | There are a few items that can't or shouldn' | ||
| + | * Waveshare Core3S500E Xilinx Spartan-3E FPGA board. https:// | ||
| + | * Xilinx Platform Cable USB Programmer. Also available from Waveshare (https:// | ||
| + | * SPI ROM Programmer. The usual MiniPRO TL866CS works fine. | ||
| + | * A USB-to-serial adapter. The board is designed to use the Adafriut FTDI Friend (https:// | ||
| + | * 2x "2mm Pitch 2x30 Pin 60 Pin Female Double Row Straight Pin Header Strip." | ||
| + | * A 5V, 2A, 5.5mm x 2.1mm regulated DC power supply (wall wart). Very common, buy at your favorite supplier. | ||
| + | * A 6-32 screw and nut for the LM1086 voltage regulator. | ||
| + | * [Multicomp] A microSD breakout board. Search Ebay/ | ||
| + | * [Multicomp] A 1 GB or greater microSD card (SDHC). | ||
| + | * [PDP-10/X] A 256 MB or greater compact flash card, and some way to get a disk image onto the flash card. | ||
| + | * [PDP-10/X] A compact flash to IDE adapter. They are available | ||
| + | The rest of the BOM is listed in the table below. Here is {{PDP10X_Mouser.txt|text file}} that you can copy & paste in to Mouser' | ||
| + | ^ Reference ^ Quantity ^ Item ^ Description ^ Mouser Part No. ^ | ||
| + | | C101, C102, C601 | 3 | 10uF | Tantalum Capacitors | ||
| + | | C301, C501-C505, C602 | 7 | 0.1uF | Multilayer Ceramic Capacitors MLCC - Leaded | ||
| + | | D601, D602 | 2 | 1N4148 | Diodes | ||
| + | | J1 | 1 | Barrel_Jack | DC Power Connectors Power Jacks | 490-PJ-002A | | ||
| + | | J101, J102 | 2 | Conn_02x30_Odd_Even | Headers & Wire Housings 2.00 mm FleXYZ Cost-effective Tiger Buy Square Tail Socket Strip | 200-SQT13001FD (much cheaper on eBay/ | ||
| + | | J103 | 1 | Conn_02x16_Odd_Even | Headers & Wire Housings 32P DR STRT RECPT 2MM LEAD LENGTH | 798-A3C-32DA-2DSC71 | | ||
| + | | J104 | 1 | Conn_02x12_Odd_Even | Connector_PinHeader_2.54mm: | ||
| + | | J3, J105 | 2 | Conn_01x06 | Connector_PinHeader_2.54mm: | ||
| + | | J201 | 1 | Conn_02x20_Odd_Even | Headers & Wire Housings 40P R/A SOLDER TAIL HIGH TEMP | 517-N2540-5002RB | | ||
| + | | J901, J902 | 2 | Conn_02x14_Odd_Even | Connector_PinSocket_2.54mm: | ||
| + | | J903 | 1 | DB15_Female_HighDensity | D-Sub High Density Connectors RA 15POS FEM Steel | 636-193-015-213R531 | ||
| + | | J904 | 1 | Mini-DIN-6 | DIN Connectors Mini Din Connectors | 490-MD-60SM | | ||
| + | | JP201 | 1 | Jumper | Connector_PinHeader_2.54mm: | ||
| + | | Q901, Q902 | 2 | 2N7000 | MOSFET N-CHANNEL 60V 200mA | 512-2N7000 | | ||
| + | | R301, R302, R303, R313, R314, | ||
| + | | R305, R306 | 2 | 220 ohm resistor | Carbon Film Resistors - Through Hole 220ohm 5% 1/4W | 603-CFR-25JT-52-220R | | ||
| + | | R401-R425 | 25 | 33 ohm resistor | Carbon Film Resistors - Through Hole 33 Ohm 5%TR 1/4W | 603-CFR-25JR-5233R | | ||
| + | | R601, R801, R802 | 3 | 1K ohm resistor | Carbon Film Resistors - Through Hole 1/4W 1K Ohm 1% | 603-CFR-25JT-52-1K | ||
| + | | R602, R603 | 2 | 1.8K ohm resistor | Carbon Film Resistors - Through Hole 1.8K ohm 1/4W 5% | 603-CFR-25JR-521K8 | | ||
| + | | R805, R902 | 2 | 560 ohm resistor | Carbon Film Resistors - Through Hole 1/4W 560 Ohm 5% | 603-CFR-25JR-52-560R | | ||
| + | | R903, R905, R907 | 3 | 680 ohm resistor | Carbon Film Resistors - Through Hole 680 OHM 2% 1/4W | 660-CFS1/ | ||
| + | | R904, R906, R908 | 3 | 470 ohm resistor | Carbon Film Resistors - Through Hole 470 OHM 2% 1/4 | 660-CFS1/ | ||
| + | | U1 | 1 | LT1086-3.3 | LDO Voltage Regulators 3.3V Low Dropout Pos VR 1.5A | 584-LT1086CT-3.3# | ||
| + | | U301 | 1 | W25Q32JV | NOR Flash spiFlash, 32M-bit, DTR, 4Kb Uniform Sector | 454-W25Q32JVDAIQ | | ||
| + | | U501-U505 | 5 | AS6C4008-55PCN | SRAM 4M, 2.7-5.5V, 55ns 512K x 8 Asynch SRAM | 913-AS6C4008-55PCN | ||
| + | | U601 | 1 | DS1337 | Real Time Clock IC Serial Real-Time Clock | 700-DS1337 | | ||
| + | | U901 | 1 | 74LS244 | Buffers & Line Drivers Tri-State Octal | 595-SN74LS244N | | ||
| + | | X301,X601 | 2 | 8 pin DIP Socket | IC & Component Sockets 8P TIN PIN TIN CNT | 575-144308 | | ||
| + | | X501-X505 | 5 | 32 Pin DIP Socket | IC & Component Sockets 32P TIN PIN TIN CONT | 575-1144632 | | ||
| + | | X901 | 1 | 20 pin DIP Socket | IC & Component Sockets 20P TIN PIN TIN CONT | 575-199320 | | ||
| + | | Y601 | 1 | 32.768 kHz | Crystals 32.768KHz10ppm 6pF | 695-CFS-20632768EZBB | ||
| + | | A901 | 1 | WIZ830MJ | WIZ830MJ: Networking Modules W5300+MAG JACK | 950-WIZ830MJ | ||
| + | | BT601 | 1 | CR3032 | Coin Cell Battery 3V 30 X 3.2 MM 500mA | 658-CR3032 | | ||
| + | | X601 | 1 | Battery_Cell | Coin Cell Battery Holders 20MM VERT SLIMLINE | 534-1065 | | ||
| + | <note important> | ||
| + | To be continued... | ||
