builderpages:abingham:cpld-compatibility [2015/12/27 14:45] admin |
builderpages:abingham:cpld-compatibility [2015/12/27 20:56] (current) admin |
Line 3: | Line 3: | ||
===== Overview & Part Numbers ===== | ===== Overview & Part Numbers ===== | ||
- | There was a question about it if would be possible to use Altera CPLDs in the [[http:// | + | There was a question about it if would be possible to use Altera CPLDs in the [[http:// |
- | [[http:// | + | [[http:// |
[[https:// | [[https:// | ||
- | Note that the orginal part specificed is ATF1508AS-10JU84, | + | Note that the orginal part specificed is ATF1508AS-10JU84, |
- | The corresponding Altera part would be an EPM7128SLC84-10N. | + | The corresponding Altera part would be an EPM7128SLC84-10N. Here are the relevant pin diagrams from the two datasheets: |
- | Here are the relevant pin diagrams from the two datasheets: | + | |
- | The only major difference between the two appears to be that the ATF1508 part has as GCKL3 pin, which is not present on the MAX7000S part. Otherwise based on the overall datasheets, the parts appear to be pin-compatible. | + | The only major difference between the two appears to be that the ATF1508 part has as GCKL3 pin, which is not present on the MAX7000S part. Otherwise based on the overall datasheets, the parts appear to be pin-compatible. |
- | **The implementation provided by John M. is written in WinCUPL for the ATF1508. | + | |
+ | **The implementation provided by John M. is written in WinCUPL for the ATF1508. To use an alternate Altera part, a VHDL or Verilog implementation of the logic equations would be required and would need to be written and tested by the board builder.** | ||
===== Hardware Cost Comparison ===== | ===== Hardware Cost Comparison ===== | ||
- | Note - if comparing the cost of *new* hardware for these two systems, the Atmel hardware is less expensive than the Altera hardware. | + | Note - if comparing the cost of *new* hardware for these two systems |
- | Altera MAX 7000S CPLDs may be purchased from UTSource.com in China. There are many $10 Altera USB Blaster clones on eBay, but they may not be 100% reliable. | + | |
+ | **Altera MAX 7000S CPLDs may be purchased from UTSource.com in China. There are many $10 Altera USB Blaster clones on eBay, but they may not be 100% reliable. Buying an eBay programmer and chips from UTsource brings the cost down to less than the cost of the Altera parts, but possibly at the cost of reliability of the setup. ** | ||
+ | ^Atmel ATF1508 @ Digikey ^Altera MAX7000S @ Digikey ^Altera MAX7000S @ eBay/ | ||
+ | |[[http:// | ||
+ | |[[http:// | ||
+ | |**Total - $73.52 start-up, $13.50/chip recurring** | ||
===== Development Software Comparison ===== | ===== Development Software Comparison ===== | ||
+ | The development software packages for these two options vary: | ||
+ | * Atmel " | ||
+ | * [[http:// | ||
+ | * Altera " | ||
