boards:ecb:4pio-i2c:development [2021/05/20 09:48]
b1ackmai1er
boards:ecb:4pio-i2c:development [2023/02/18 23:19] (current)
b1ackmai1er
Line 36: Line 36:
       * Change top layer to vcc plane for better power distribution.       * Change top layer to vcc plane for better power distribution.
       * Gate /WR with /CS to meet PCF8584 Z80 configuration requirements.       * Gate /WR with /CS to meet PCF8584 Z80 configuration requirements.
-      * Version C committed including above changes+      * Version C committed including above changes
 +      * Patches to version B board
 +        * Lift pin 1 IC15, connect lifted pin to pin 19 IC13
 +        * Lift pin 18 IC16, connect lifted pin 18 to pin 20
 +        * Lift pin 5 IC 7, connect pin 6 to pin 15
 +        * On solder side connect pin 19 IC13 to pin 2 IC2
 +        * On component side, cut track between IC16 pin 17 and IC13 pin 19.
   * 4PIO-I2Cd   * 4PIO-I2Cd
       * Component placement, routing changes.       * Component placement, routing changes.
       * Initial ROMWBW HBIOS support.       * Initial ROMWBW HBIOS support.
       * Add jumper to connect DS1307 battery backup to backplane battery backup.       * Add jumper to connect DS1307 battery backup to backplane battery backup.
 +      * Add support for 3.3v I2C peripherals using logic level translator.
 ====== Board ====== ====== Board ======
Line 46: Line 53:
 Kicad files can be found [[https://github.com/b1ackmai1er/ECB-4PIO-I2C|here ]]but may not be the most recent. Kicad files can be found [[https://github.com/b1ackmai1er/ECB-4PIO-I2C|here ]]but may not be the most recent.
-Current revision is ECB-4PIO-I2Cc+Current revision is ECB-4PIO-I2Cd
 ====== Pictures ====== ====== Pictures ======
Line 80: Line 87:
 ====== I2C Addressing ====== ====== I2C Addressing ======
-24LC512 devices are access on the I2C bus by first issuing a control byte. The control byte consists if a device identifier (D), the device address (A) and a bit (B) to indicate if a read or write operation (O) is intended.+24LC512 devices are access on the I2C bus by first issuing a control byte. The control byte consists of a device identifier (D), the device address (A) and a bit (O) to indicate if a read or write operation is intended.
 So accessing a device requires sending a bye in the following sequence: DDDDAAAO So accessing a device requires sending a bye in the following sequence: DDDDAAAO
Line 108: Line 115:
 ^WRITE|11010001 (D1)| ^WRITE|11010001 (D1)|
-{{:boards:ecb:4pio-i2c:development:pcf8574.pdf|PCF8574}}  > {{:boards:ecb:4pio-i2c:development:hd44780_lcd_driver_datasheet.pdf|LCD}}  {{https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=5ed9e3&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=f3f91e&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=f46157&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=b40609&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?media=boards:ecb:4pio-i2c:development:i2c-lcd-backpack.png?linkonly|backpack}}+{{:boards:ecb:4pio-i2c:development:pcf8574.pdf|PCF8574}}  > {{:boards:ecb:4pio-i2c:development:hd44780_lcd_driver_datasheet.pdf|LCD}}  {{https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=0bc8fd&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=842ba7&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=100ca2&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=10f051&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=5ed9e3&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=f3f91e&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=f46157&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?tok=b40609&media=https://www.retrobrewcomputers.org/lib/exe/fetch.php?media=boards:ecb:4pio-i2c:development:i2c-lcd-backpack.png?linkonly|backpack}}
 A PCF8574 I2C 8-bit I/O expander is commonly used to driver LCD displays. A PCF8574 I2C 8-bit I/O expander is commonly used to driver LCD displays.
Line 123: Line 130:
 __ROMWBW __ __ROMWBW __
 <code> <code>
 RomWBW HBIOS v3.1.1-pre.75, 2021-05-12 RomWBW HBIOS v3.1.1-pre.75, 2021-05-12
Line 144: Line 151:
 PPIDE: IO=0x20 PPI NOT PRESENT PPIDE: IO=0x20 PPI NOT PRESENT
 PPIDE: IO=0x44 PPI NOT PRESENT PPIDE: IO=0x44 PPI NOT PRESENT
 </code> </code>
Line 153: Line 161:
 H>rtchb H>rtchb
 01/01/21 00:03:19 01/01/21 00:03:19
 </code> </code>
Line 160: Line 169:
 H>rtcds7 H>rtcds7
 01/01/21 00:03:35 01/01/21 00:03:35
 </code> </code>
Line 177: Line 187:
 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
 70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
 </code> </code>
Line 190: Line 201:
 Linux C driver: [[https://code.woboq.org/linux/linux/drivers/i2c/algos/i2c-algo-pcf.c.html|https://code.woboq.org/linux/linux/drivers/i2c/algos/i2c-algo-pcf.c.html]] Linux C driver: [[https://code.woboq.org/linux/linux/drivers/i2c/algos/i2c-algo-pcf.c.html|https://code.woboq.org/linux/linux/drivers/i2c/algos/i2c-algo-pcf.c.html]]
 +I2CScan code: [[https://groups.google.com/group/retro-comp/attach/25120f43d0386/I2CSPI.ZIP?part=0.1|https://groups.google.com/group/retro-comp/attach/25120f43d0386/I2CSPI.ZIP?part=0.1]]
 ====== Key Learnings ====== ====== Key Learnings ======
Line 198: Line 211:
   * Do a hard reset between each software test to ensure consistent results. Exiting in a known state is important.   * Do a hard reset between each software test to ensure consistent results. Exiting in a known state is important.
   * Software control of hard reset is desirable as soft reset does guarantee consistent results.   * Software control of hard reset is desirable as soft reset does guarantee consistent results.
boards/ecb/4pio-i2c/development.1621518522.txt.gz · Last modified: 2021/05/20 09:48 by b1ackmai1er
