Thanks Sergey.
Thankyou for all the replies everyone.
Sam
On Tuesday, 26 February 2013 03:31:18 UTC, Sergey wrote:
Sam,
I agree with Bob. Don't take 4.5V power supply, find 5V one instead. I
would also avoid using power supply with interchangeable plugs or
switchable voltage...
Take a look at this one, it should work:
http://www.ebay.co.uk/itm/UK-AC-Wall-110-240V-To-DC-5V-2A-Power-Supply-Charger-Adapter-Plug-/290770066033?pt=UK_Sound_Vision_Other&hash=item43b33f1a71
Regarding the plug, the jack on the board will fit connectors with 5.5
mm - 6 mm outside diameter and 2 mm - 2.5 mm inside diameter. Another
important thing about the plug - it should have (+) terminal inside
and (-) outside. While this is a more common arrangement, it is not
unusual to have the opposite arrangement as well.
An available source of 5V supplies is USB chargers. Just replace the
USB plug with the cylindrical DC one...
Sergey
On Feb 25, 6:43 pm, Bob Grieb <bobg...@yahoo.com> wrote:
> Sam,
> That supply doesn't seem to have 5V as one of its settings. Long term I think you want a
> 5V power supply for TTL logic chips. That's what everything was designed for.
> Bob
> ________________________________
> From: Samuel Castledine <samuel.c...@gmail.com>
> To: n8...@googlegroups.com
> Sent: Monday, February 25, 2013 8:36 PM
> Subject: [N8VEM: 15698] Re: Testing teh Zeta
> Ah cool thanks, Ill test the board tomorrow.
> Unfortunately I don't have any PC power supplies kicking around so was hoping to find a wall socket one instead.
> Using Sergeys criteria I've found this one on eBay which I think will work as long as I can get a Jack from mouser or somewhere. It seems that the plug I've used is an unusual size as all the supplies I've found are about 0.5 mm smaller/bigger.
> On Monday, 25 February 2013 10:01:57 UTC, Samuel Castledine wrote:
> Hello,
> >I've finally finished constructing my Zeta board and I'm currently looking for power supplies for it. But is there a way of testing that the board is set up OK before buying eh power supply? I think Sergey mentioned using 3xAA batteries?
> >Sam
> To unsubscribe from this group and stop receiving emails from it, send an email to n8vem+un...@googlegroups.com.
> Visit this group athttp://groups.google.com/group/n8vem?hl=en.
> For more options, visithttps://groups.google.com/groups/opt_out.
