Re: Video Card For xi 8088
Well, it does look that this card supports 8-bit bus with auto-
sensing: http://www.vgamuseum.info/images/stories/doc/ati/integra-basic16.pdf
Other things to check / try:
- Do you see any of these codes on the display:
e_video_bios_ok   equ   11h         ; Video BIOS found
e_video_init_ok   equ   12h         ; Video BIOS initialized
Normally there is a slight delay on code 11h, while the video BIOS
initializes the card, checks memory, etc.
- Do you have any of J4 jumpers installed? If you do, please remove
them.
Sergey
On Feb 21, 2:54 pm, Doug Wood <whitb...@gmail.com> wrote:
> Sergey
>     I only have the 1 system to try it on.
> It was listed as 8/16 Bit compatible.
>       Thanks
>              Doug
> On Friday, 15 February 2013 20:46:06 UTC-5, Doug Wood wrote:
> > Hi all
> >   Im looking for an ISA video card for the xi 8088 project.
> > Ebay has lots listed but i need to know if a 16 Bit card will work
> > or 8 bit only. Also is there a preferred video card model ?
> > Thanks
> >             Doug Wood
