Re: [N8VEM: 14700] Re: LED Orientation
SBC v2 uses a 2-lead bi-color LED at D1 (per schematic).  Red/Green is suggested.
Depending upon your drivers (LS or HCT), you may wish to reduce the value of R9 from 100 ohms to 47 ohms to increase brightness.  I wasn't satisfied with the LED brightness until I reduced R9 to 22 ohms -- but I am using LS logic throughout the board.  Keep the 100 ohm value to start if you are using HC or HCT logic.
On 09/24/2012 07:04 PM, LucasFraser wrote:
So, I'm still a bit confused... Is it a single or bi color LED? Parts list specifies a single color one but you are all saying it is red/green?
On Tuesday, September 25, 2012 6:08:43 AM UTC+9:30, Sergey wrote:
Or just connect the LED to a 5V through 470 ohm resistor, and check
the polarity and the colors :-)
On Sep 24, 1:10 pm, John Coffman <john...@gmail.com> wrote:
> The leads on the LED are distinguished 1 & 2 by length.  Lead 1 is the longer lead; and lead 2 is the shorter.
> The square pad marks pin 1.
> --John
> On 09/24/2012 03:05 AM, LucasFraser wrote:
> I have the SBC V2 --
> To view this discussion on the web visithttps://groups.google.com/d/msg/n8vem/-/fpNcTNJTvzcJ.
> To post to this group, send email ton...@googlegroups.com.
> To unsubscribe from this group, send email ton8vem+u...@googlegroups.com.
> For more options, visit this group athttp://groups.google.com/group/n8vem?hl=en.
To view this discussion on the web visit https://groups.google.com/d/msg/n8vem/-/_tXU828C3ooJ.
